997.1 TT finished installing AMS Alpha 9 kit
The tiptronic transmission will hold 1000 Nm / 740 ftlb all day. You need to modify the TCU in order to make use of that torque, but the transmission itself is pretty reliable and can take a lot of abuse.
Good to know! He should be fine then at his current power level. I wish I could modify the TCU on my 996 Turbo!
No need to do so. No torque limiter, only rev limiter. Shifting times could be optimized though
I'd like to max out the capability of what the alpha 9 kit can put down, but do not want to get into building the motor. So whatever the car can safely handle without bending a rod is where I want to be. I understand that no matter what that can still happen, however want to stay within the limits of what is considered a safe zone and see what happens. At the end of the day you are playing with fire one way or another, so anything can happen, I get that.
I'm looking into going the same route also with a tiptronic. With that magnitude of a kit how beneficial would a proEFI or Syvecs ecu be? I believe Syvecs controls the TCU as well and might be more tiptronic friendly.
Is there a reason you went alpha 9 ? Upgraded vtg's will give you the same power. I am sure alpha 9 will make a bit more on pump gas but then again most people who move away from VTGs build the motor+ and turn the power way up.
AMS makes a good product, relatively complete and no real need to start swapping out parts down the road for larger more capable ones.
Gives me room to grow easily. Do I want to turn the hp way up, yes who doesn't? But I don't want to build a motor, in the event I'm faced with that decision at least I know 1000hp isn't that far away.
I absolutely love the Alpha kits! They are just works of art with OEM and better quality!
With amazing built quality like it was from the factory, these packages can run 5.9 ON PUMP what well put together and tuned VTG'S run on E85!!
On E85 or even pump and METH these AMS packages ON STOCK ENGINES run 5.2(PTF'S car on pump and METH) - 4.8 (Prodgymb) 60-130!!! All that performance on stock engine with room to grow with a built motor!
If I wanted to put more $$ in my car I want a AMS package in my car!
In the mean time I run E85 all the time on my 63.5m VTG'S And it does the job until the time for a AMS package!
Congrats on the build...really can't wait on your review I'm so on the fence about which turbo to get...and it really comes down to 68mm or alpha 3076....I'm not sure if you posted but what fuel are you running and please give me the heads up on how those turbos run....detuned to handle your tranny....nice job...
