Sponsored by: Bears Transport
Dumb DSC Q
Old 11-29-2016, 06:50 PM
Rez90's Avatar
Rez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond repute
So for a new TPC DSC customer......for the new product there will be 2 modes...correct?
Just like stock...only enhanced....am i correct?
Old 11-29-2016, 07:08 PM
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
Correct, new customers get the new and improved firmware. 2 modes, night and day difference from stock...
Old 11-30-2016, 06:14 AM
Rez90's Avatar
I want to order this mother so bad but the reality is if i do i'm going to take my car out on a 30 degree day to "Test" the new suspension and end up in a tree.
Probably going to wait until the spring.
Old 11-30-2016, 07:34 AM
good thing its still 50 up here
#TeamAIM
Old 11-30-2016, 08:25 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
What setting is best to counter wheel hop? Soft or firm?
Old 11-30-2016, 10:58 AM
akunob's Avatar
I'm no expert but the firmer setting should counter wheel hop better. Why, while I have never experienced it, wheel hop is likely due to loss of traction under hard acceleration. The firmer setting reduces body roll (squatting) under hard acceleration and as a result during acceleration there should be less 'play' in the rear of the car which provides better traction and more grip. That is why launch control defaults to the Sport PASM setting.
That said, I wouldn't rely solely on the DSC module to eliminate all wheel hop as there are likely other factors contributing to your wheel hop beyond mere suspension damping rates, although I am confident that the DSC module should minimize the effects. Hope this helps. I say try both settings and see which feels better (that's an easy real world test).
Old 01-20-2017, 04:40 PM
PPower's Avatar
PPower is on a distinguished road
Does the new two mode DSC retain launch control which normally runs in Sport Plus mode?
Old 01-20-2017, 07:30 PM
Nate Tempest's Avatar
Nate Tempest is an unknown quantity at this point
Originally Posted by naterry
I just installed TPC's black box as well. Driving impressions are in line with most people on here, all good.
However, I do have one issue with the new version vs what I've read of the old 3 mode version. Specifically, why does it force PASM into sport mode when selecting Sport Plus? I've always preferred a more compliant setup and don't know why they would lock you out of PASM "normal" when selecting "Sport Plus". It seems intuitive that the programmers would retain all of the permutations possible with the hardware and software.
Perhaps there's a setting I'm missing, please enlighten me if so.
Can anyone elaborate on this? Are you saying that it locks PASM in sport mode when engaging the sport button? Or just that it defaults to sport, but you can still switch it back to comfort (ie identical to how it functions stock)? I assume the latter, which I agree isn't ideal, but it's not a deal-breaker.
Old 01-21-2017, 07:35 PM
akunob's Avatar
Short answer, yes it should. The module simply defaults to PASM Sport mode when Sport Plus is engaged
Old 01-21-2017, 07:43 PM
akunob's Avatar
I can confirm that with the new software (2 mode), PASM Sport mode is engaged when Sport Plus is activated. Comfort mode cannot be selected when in Sport Plus (at least not on the version I have), PASM Sport mode is locked in. Sport mode however allows for toggling between PASM Comfort and Sport modes.
Old 01-21-2017, 08:36 PM
PPower's Avatar
Thanks!
Old 01-22-2017, 01:43 AM
Ah, I see. I'm on a 997.1tt, so no Sport Plus.
Old 01-22-2017, 02:03 PM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
same behavior as my DSC.
I think there should be an update to make it behave like stock.
i cannot have SportPlus with no sport PASM
Old 01-22-2017, 04:37 PM
akunob's Avatar
I hear you, some like the option of pairing PASM Comfort mode with Sport Plus. The one thing I will mention is that the difference between TPC Normal and Sport modes is more subtle than in prior versions and is really felt when the car is pushed hard (i.e., quicker damping response activated much earlier). The module's 2 modes aren't night & day different like the OEM Normal/Comfort vs. Sport. The difference is more progressive. If you don't already own the TPC module, I would still give it a try, you might be pleasantly surprised.
