Sponsored by: Bears Transport
Planning on some mods in the spring....Am i missing anything?
Old 12-05-2016, 06:58 AM
Rez90's Avatar
Rez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond repute
Currently the car has
AWE Exhaust
AWE Intercoolers
GIAC Tune
PSS10's (Damptronic)
Swar Bars
Sachs 2.5
BBI Slave
Porsche Sport Shifter
Planned for the spring
TPC DSC
Injectors
Intake Tubes
Y Pipe
Throttle Body
Plenum
BMC Air Filter
Cobb with E85 and Pump tune
Missing anything? Should i have the coolant pipes pinned? Any other suggestions? I want the car to be a bolt on car with as close to factory reliability as i can get. I plan to make sure the tune is safe and conservative even if i have to give up a few ponies.
I want the car to be DONE at this point and hopefully not have to bring it to another shop for a long time.
Old 12-05-2016, 01:15 PM
Add a bump steer kit for the front and rear that really helps lowered cars not feel as "darty" on the highway when going over uneven pavement..... jersey has quiet a bit of that.
#TeamAIM
Old 12-05-2016, 01:25 PM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
If you are dropping the engine then definitely do the coolant pipes, all 10 of them. 7 aluminum ones and the 3 plastic ones. If you know how to or have access to an experienced TIG welder I would weld them instead of pinning. The 3 plastic ones could be replaced by the stainless ones Sharkwerks sells. This is what I did on mine.
Old 12-05-2016, 05:47 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
Also recommend motor mounts if the motor is out - transmission mounts as well is a nice cheap upgrade.
Old 12-06-2016, 05:50 AM
Rez90's Avatar
Thanks for the info. I'll likely take care of all the coolant pipes and look into the bump steer kit. Motor mounts i'll skip because i'm not trying to bring any more vibration into the cabin.
Old 12-06-2016, 08:22 AM
superslow's Avatar
superslow is an unknown quantity at this point
how many miles does you car have?
Old 12-06-2016, 10:57 AM
Rez90's Avatar
37,500
Old 12-08-2016, 07:39 AM
superslow's Avatar
I have essentially the same mods/ car / miles
doing just about everything here:
https://www.6speedonline.com/forums/...motor-out.html
Old 12-08-2016, 09:51 AM
TimeTomorrow's Avatar
TimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to beholdTimeTomorrow is a splendid one to behold
BMC air filter is a pretty dubious upgrade. I've seen pictures of the surround breaking down. I'd skip it.
Old 12-10-2016, 08:38 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
dude... as if you dont know what im doing with my car... you ask the interwebs???
edit; ok that was ego talking lol
in all honesty when youre ready to do it let me know and i'll send you all part numbers
I am planning on doing a full write up here with photos as i have extensive pics of most of the engine stuff we did.
second edit: Softronic over GIAC, just sayin' (i can also get you a disc on that)
Old 12-10-2016, 04:06 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Good list, I'de hold on the plenum and throttle and do so ething else, without a big turbo setup I don't think its worth its price and hassle. If you track look into an lsd or a tbd, I use wavetrack and its really good.
How about a refresh to old rubber hoses, water pump, thermo, belt, rollers.
Front cv boots go bad on these cars often, good opportunity to change cv's and wheel bearings.
Good luck
