1500whp on Ethanol and 1000whp on 93 Build
no events for me for several months. snow on the ground. I tried to get on the waiting list for the wanngofast in florida Jan 20-21 but they were full and said I can do just 1 day. tough to justify pulling the car down and bringing a crew for 1 day of testing. we still have some stuff to tinker with and add before its event ready.
- set up individual EGTs and controller box for them, wire into proefi
- pump e85 tuning
- ignite 114 tuning
- wire up Motec dash and logger
- reassemble
XONA 9567, its like a 6867ish
- pump e85 tuning
- ignite 114 tuning
- reassemble
#TeamAIM
#TeamAIM
theres another wannagofast at immalooki fl in march? also theres an event at clayton ga in may . both havent started registration yet
Last edited by Mark @ AIM Performance; 01-12-2017 at 11:59 AM. Reason: external links
yep here is the video ...
here is another video of a couple quick revs just to give you an idea how it fast it revs up. this is also with the valves closed in the exhaust so it sounds like an actual car
#TeamAIM
#TeamAIM
https://youtu.be/WInIfSODq4M
https://youtu.be/FnckwM2BEPU
15-16psi? That seems a extremely low to make 1000whp...
yep it has 15 pound wastegate springs and runs 15-16psi of boost right now.
that's what happens when you slap two turbos on that flow 95 pounds per minute each and rev it to almost 8000.
#TeamAIM
#TeamAIM
Outright AMAZING!
Can't wait to see this thing with some E85 and turned up!
Please get some numbers on this pump set up (60-130, 1/4 traps etc), before you turn her up on the corn. Very interested the #'s it would do with the same tune/dyno as above.
Nice job Mark!
Nice job Mark!
Hard to believe it to be honest... What compression?
