1500whp on Ethanol and 1000whp on 93 Build
Old 01-13-2017, 10:02 PM
Originally Posted by Emre@Esmotor
Congratulations on your new build Mark,
Very nice curve for pure 93 octane.
thanks Emre. we are just little guys trying to keep up in the HP rat race to the moon
Originally Posted by Realife
If you have few pictures of the cracked/intact piston that will provide the answer to this matter.
his kit was from Wrightwood. that is the heavier piston with lower compression of 8.8 .... not the same as the FVD kit.
Originally Posted by AriS4
I am not certain - I had gotten them from Dave @ TRE - designed by Wrightwood Racing; I got them - 1st round when I was building the 3.8L (102mm)
thanks for the info. would def like to see pics as well.
#TeamAIM
  #62
Old 01-13-2017, 10:22 PM
AriS4's Avatar
AriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond repute
Very interesting to know what 102mm Mahle set U cracked (FVD ? , PORSCHE MOTORSPORT ?...) as I'm at the same power level +- with Mahle 102mm kit and it will be very helpful to know what kit was it before hand to prevent failure during the season... it will be great if Betim will agree to shim in on it.
I think FVD and Mahle MS are the same things - all done by Wrightwood. TRE and FVD are just resellers. Charlie (wrightwood) does not like talking to end users ..
I was on Pauter Rods .. and I switched over to Carillo's as well . As owner of pauter even said 1000-1100 awhp is pushing it for the off the shelf stuff
Also the wrist pins with the Mahle MS are good for about 1000 awhp as well then they start flexing. I am running some wrist pins almost solid ish ...
  #63
Old 01-13-2017, 10:30 PM
I thought this too at first but the FVD kit is actually in fact different. The FVD pistons are lighter and higher compression and they have different webbing design in the back of the piston. They are made by Mahle for FVD Germany exclusively not thru Wrightwood. Tim had a set of the Wrightwood MS ones and I will try and snap a picture of them if he hasn't put them into an engine yet. With all of that said I am not sure if they are any stronger or not, I just know they are not the same.
I appreciate the insight ! Did you go with CP HD? Still using old liners or going Darton or LA?
#TeamAIM
  #64
Old 01-13-2017, 10:57 PM
AriS4's Avatar
I used same liners - Mahle MS - but new set - Betim had access to a new set .
OFF TOPIC !! - I still don't know if I am OK with my clutch ( same one you have ); under full load that thing is not gonna want to shift - unless grannied just my feeling....
Also - tranny... do you know what you are going to do ? 3rd gear does not like 1000 ft. tq ..
  #65
Old 01-13-2017, 11:13 PM
Ask rob if your clutch has the springs in the pressure plate. That's what ended up fixing the hang up at high RPM finally.
This is my friends 997 that got the first one with those springs. So far we raked up 2-3k miles and 2 track days and no issues. I have the same thing in my car but it has only seen the dyno so far.
shift speed is nice :
#TeamAIM
  #66
Old 01-14-2017, 03:40 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Great build Mark ... Twin 42's you're nuts!!
Congrats and enjoy in good health ...
  #67
Old 01-14-2017, 09:42 AM
AriS4's Avatar
That looks like it is certainly moving does he have the the cables and shifter etc ? I got the new smaller diameter clutch from Rob - I think that is the latest. And like you - I only have dyno time and 1 shift sector event. Then 1 weekend playing; where it just sheered off 3rd gear ... now "contemplating" what to do next.
I did not do the DSS axles - only hoping to leave as the weakest point as an insurance vs the tranny etc. but to have a solid launch perhaps it needs to be on the list.
Back to your car... That thing is gonna be INSANE !!! Be safe and enjoy in good health as mine was beginning to scare the crap out of me -which I LOVE
Are you building for 1/2 mile or mile ? I think you will need a 7th gear and an extra set of ***** for a mile - these cars are getting too fast too quickly.
  #68
Old 01-14-2017, 05:30 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
My 3,8 kit is the Mahle for FVD as well, rated 9.4/1...
Sincerely it is very nice, high finition, parts balanced and weight engraved.
  #69
Old 01-14-2017, 07:32 PM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
Originally Posted by brnrdtns
It seems like porting factory heads is a waste of time for a bigger build. Just go straight to the GT3 heads.
I made 960 WHP and 790 TQ @ 17 psi on turbo heads and stock IM. They flow fine.
  #70
Old 01-15-2017, 05:45 AM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
Team Insanity of NY is waiting for a rematch brother man! lol
  #71
Old 01-15-2017, 12:40 PM
Realife's Avatar
Realife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud ofRealife has much to be proud of
These are great numbers! On what fuel?
  #72
Old 01-15-2017, 03:47 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Great HP bro ..
enjoy it .. you deserve it as always
  #73
Old 01-15-2017, 11:38 PM
m5q8's Avatar
m5q8 is on a distinguished road
https://youtu.be/P6sYrRDEm1E
With 60lb for your friend turbos make a real power and track number... I would like to see what your 90lb do soon..
Good luck ...
  #74
Old 01-15-2017, 11:48 PM
kbhaw's Avatar
kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !kbhaw Is a GOD !
congrats on the number!! wow
  #75
Old 01-16-2017, 06:59 AM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Good God Mark! I know i am late to the game but congrats on your much well deserved accomplishement. That torque line is damn sexxy.
