Go Back   6speedonline.com Forums > Porsche (Present) > 997 Turbo / GT2 > 997 Turbo Vendor Classifieds
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-20-2009, 03:31 PM #1
vividracing's Avatar
Platinum Sponsor
2007 Porsche 911
vividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond repute
Send a message via AIM to vividracing Send a message via MSN to vividracing Send a message via Yahoo to vividracing Send a message via Skype™ to vividracing
Agency Power Race Throttle Body/Plenum Kit 20+HP Gain - INTRO OFFER
Adding bolt-on horsepower to the 997 Turbo is a continuous quest by many enthusiasts looking for more power. Reverting back to old tuning technologies, Agency Power has developed a larger throttle body and plenum kit for the Porsche 997 Turbo to gain added performance. The point of a larger throttle body is to get in more air. The more air you bring in, the more power you make. The 997 Turbo's engine intake system works off pulses, so how that air is diverted to either side of the engine is not as important as the volume incoming. The plenum kit includes an OEM Porsche Cayenne Turbo throttle body (part# 94860511503) which is a direct bolt on and plug in for the electronic throttle control with no modifications needed. This throttle body has a 77.64mm inner diameter compared to the stock one of 75.64mm. We chose to go with this smaller diameter throttle body to give the car more low end horsepower and torque. If the diameter of the throttle body is to big, it will increase turbo lag and performance gains will only be made at the mid to top end RPM range. Since most 997 Turbo users drive their car on the street and track, we developed this product to substantially increase throttle response and improve "usable" power.
The Agency Power plenum kit is made using high quality 6061 aluminum that has been TIG welded and pressure tested in a T shape to mimic the OEM design. The CNC machined 4 bolt throttle body flange features a groove to accompany a rubber o-ring to ensure a secure and sealed fit with the OEM Porsche Cayenne throttle body. The T plenum features the necessary fittings for stock vacuum hoses and breather lines and includes a 1 way check valve needed. Each T plenum is powder coated gloss black for an OEM look and includes new silicone couplers in black and worm clamps to secure it to the factory intake manifolds. The installation of the plenum requires removal of the factory airbox and Y pipe to access the component. Recommended installation time is approximately 3 hours.
Installation of the Agency Power plenum kit DOES NOT require the ECU to be flashed. The factory ECU will adjust accordingly to the change in throttle body diameter. However, corresponding mods including an ECU flash will only bring out additional power. As it stands alone, the plenum kit will add a bolt on 20 wheel horsepower to your Porsche 997 Turbo. As tested on a VR700 kit, the plenum added nearly 45 horsepower and 60 ft/lbs of torque. This product features the Agency Power 90 day warranty and is Made in the USA.
Introductory Offer of $700 shipped for the Kit.
30 Day Money Back Guarantee.
More product info and pictures here - http://www.vividracing.com/catalog/a...9-p-79632.html
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
View Our 105% Price Match Guarantee -
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
1-866-44-VIVID 1-480-966-3040 x222
***WE SHIP WorldWide***
View Our
at Texas Mile
Fastest K24/18G Tiptronic
Old 10-25-2009, 09:40 AM #2
ysfg35 is on a distinguished road
nice work
997tt 2008 white still moddin
996tt 2003 black (sold)
coevette c5z06 (sold) 798whp
Old 10-25-2009, 01:54 PM #3
996TTer's Avatar
996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future996TTer has a brilliant future
Looks great! Do you have a DIY right up?
Old 10-26-2009, 10:46 AM #4
Platinum Sponsor
2007 Porsche 911
1st remove the Ypipe by loosening the clamps that hold the Ypipe to the throttle body and on either side to the boost hoses. Make sure to UNPLUG the MAP sensor -
Once you have moved the ypipe out of the way, undo the throttle body with the 4 Torx bolts.
Then use a long flat head or 8mm to loosen the clamps that hold the plenum to the each intake manifold on the left and ride. Once loose you will need to slide the black silicone couplers to the outside.
Place the new plenum in the same spot and connect the hoses and secure it with the new provided couplers. Then fasten the new throttle body to the front. Reconnect the hose from the throttle body to the ypipe and fasten the worm clamp. Remount the Ypipe, clip the MAP sensor in place, and tighten all hose clamps.
Its about a 4 hour job and it is a tight space. So be patient and take your time!
View Our
at Texas Mile
Old 11-02-2009, 09:11 AM #5
supergallardo is on a distinguished road
Looks easy enough, btw which HRE's are on the vividracing shop car? They look amazing, keep up the good work guys!
Old 11-02-2009, 09:24 AM #6
Platinum Sponsor
2007 Porsche 911
Thank you! We have the P40's in flat black right now.
View Our
at Texas Mile
Old 11-05-2009, 09:54 AM #7
i have the ipd plunim dan ... if i get this prodect ,,do i must remove the ipd plunim ??? or it can be work together ??
Old 11-05-2009, 10:00 AM #8
Platinum Sponsor
2007 Porsche 911
Yes you would completely remove the IPD plenum.
View Our
at Texas Mile
Old 11-06-2009, 05:00 AM #9
ahaaa ,, its look great .. good work dan
Old 11-10-2009, 03:40 PM #10
Platinum Sponsor
2007 Porsche 911
Thanks! I think you should switch yours out to see some bigger gains
View Our
at Texas Mile
Reply
Tags
951, 997, bigger, bodies, body, diameter, ferrari, gain, hp, kit, performance, plenum, porsche, racing, throttle, torque
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
