| 997 Turbo / GT2 2004–present Turbo discussion on the current model Porsche 911 Twin Turbo. Sponsored By ASR Engineering |
Thread Tools | Rate Thread | Display Modes |
Swapping wheels on the 997TT
Going to swap my OEM wheels for my track wheels for the first time this Saturday. I'm not particularly mechanical but had it down pat with my B6S4 Avant which the TT replaced. For some reason I am quite anxious about doing this for the first time with the TT. Few questions for those who have it down to a science:
(a) I'm going to collect a new jack from Sears (my old one is dead). I'm thinking I should get a 4000lb version. Hopefully will be sufficiently low profile to fit under the lowered car. Thoughts? (b) do you typically jack the car up using the rear mount enough so that you can change both the front and rear without relocating the jack? This used to work well on the S4. (c) how difficult is it to manouver those 305 section rears? They are literally gigantic when you see them off the car? Any suggestions appreciated. I'd prefer to have the tire shop do the work but fitting 4 wheels into the TT doesn't really work...
2008 TT Meteor/Cocoa/GMG/FarnbacherLoles 1988 BMW M5 - 44k |
| Sponsored Links | ||
Shouldnt be a problem. I swap my wheels with a fracture in my shoulder and went to 325 tire. Do make sure you have a low profile jack if you car is lowered any..
FS:Avus 501 20x8.5 and 20x11 with tires for narrowbody 997 $3000 or Best Offer |
AB
Call me on my cell I'll help you do it Fri afternoon. You can use my low profile sears jack, I'll bring it. Basically, you need a tq wrench(I have), 19mm(I have), alignment stud (I have) and I recently bought a craftsman low profile 2.5 ton floor jack(79$). Yes, you must use the jack points and a low pro jack, tq to 96 ftlbs. It's easy, I have a fast 'system'. C
Chris '07 997TT Midnight/Sea...Farnbacherloles prepped To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. '03 996 C4S-long gone |
Quote:
Hey, how did the GMG stuff work out with FarnbarcherLoles?
I picked up a racing jack from harborfreight.com:
http://www.harborfreight.com/cpi/cta...emnumber=91039 Going to be taking it with me to Summit Point for Thurs/Fri RTR PCA, havent had a chance to use it, but my car is near slammed and I'm hoping it's going to fit.
08 997TT - Bilstein PSS Damptronics, GMG Sway Bars, GMG Roll Bar w/Schroth, FabSpeed ver3 Exhaust, Champion RS171 06 Range Rover Sport SuperCharged 07 BMW M5 (Gone) 05 BMW M3 (Gone) |
Quote:
When I do the w/t thing I do 1 side at a time, jack it up at the rear point, break down all the lugs first. Then do 1 at a time, so you always have three tires on the car in case the jack fails, etc. The guide that screws into the lug holes is very useful for a quick job, our cars didn't have it, but all 996's do, pick one up at the parts counter before you do it, then tq everything to 96ft lbs and go. You'll have to reset the tpms, it will also go crazy at the track when you lower your air pressure. That 79$ craftsman low profile works great and it's small/light enough to carry around if you have to, but they also have a very nice lo pro aluminum jack, ~300$. Enjoy!
Chris, Since you swap your wheels quite a bit how often do you put new anti-seize on the studs if ever?
2008 C2S Cab Midnight Blue 2009 997TT Atas Grey Coupe (on order) |
never put anti-seize on lug bolts
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 08 Cayenne TT 07 997 tt To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 97 993 tt GIAC/AWE K24 86 944 turbo track car K27/6 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
I may be using the wrong term but I thought in the owners manual they recommended something on the studs.
I never put anything on 'em other han a torque wrench.
Got it. Thanks
Right on!
It's night and day. I almost just did the springs and sways, in the end I'm glad I did the whole 9 yards. No extra harshness/NVD at all. I had Kip set my bars in the middle f/r. 'Tight' is the only way to describe the ride now!
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
