Go Back   6speedonline.com Forums > Porsche (Present) > 997
997 Current model of the 911 C2, C2s, C4, C4S, Targa and Cabriolet Discussion.
Sponsored By HRE Wheels
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-15-2009, 11:48 AM #16
rvhpno80's Avatar
rvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud ofrvhpno80 has much to be proud of
Quote:
Originally Posted by 997t View Post
Hi, thanks for reply, im told the control unit (997.618.512.01) has to be changed and coded so you can alter the light settings via a piwis tester. the light settings have to be changed from incandescent to led, otherwise they wont function properly as leds are lower voltage.
However in each facelift light there is a module and this senses the light for the drls. (997.631.241.00) i think in my earlier post i refered to the control unit as the module, my appologies.
I wondered if i just wired up lights and fitted the control unit , then coded it, what would happen, surely the lights would work but would you need to turn the fog light switch on for the drls or would they work via the side lights? Thats the question. would they indeed, well until somebody can tell me im stumped,
Ron may be the man if AI design in NY can sort out his gen2 conversion, only problem is im in the uk and ive drawn a blank here, so im pinning my hopes on ron.
well im crossing my fingers to see what is going to happen. thanks for the info as well, as soon as i get more info in regards, i will post it asap. thanks for all the info.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
997 C4S Cab, with a K&N air intake, navi, bose, 6 speed, sport chrono,
i pod inter-grader, chrome tips, 3M bra, H.R.E C97's 19" 8.5F, 11.5R rear with michelin ps2. (P.C.A member)
Ducati 1098s with carbon fiber
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
996 Carrera Cab, Guards Red with H.R.E's 545R's 8.5F/10.5R. Sold
Old 10-15-2009, 12:38 PM #17
akshon
i just finished my install. Lights work!!
Pretty much two parts u need is the small wiring harness and a black box that is in the front of the car to the passenger side cubby. Its a black box similar to the black box for the rear led.
Once you have those two parts its all about rewiring based on the wiring diagram.
A lot of trial and error.
Best of Luck
Old 10-15-2009, 02:56 PM #18
rvhpno80's Avatar
ok cool, i will forward this over to A.I design asap, thanks for the team effort guys, this forum stuff is excellent.
Old 10-16-2009, 03:37 AM #19
997t's Avatar
997t is on a distinguished road
Akshons conversion.
Hi akshon,
do you know which wires need to be rewired, have not got a competent auto electrician near me so may have to do myself, any help or diagrams would be a help,
kind regards Tim
Old 10-16-2009, 03:46 AM #20
997t's Avatar
Is this the small harness that just plugs in to rear of the front lights? (997.612.501.25).
Old 10-16-2009, 07:29 AM #21
rvhpno80's Avatar
anymore feedback would be greatly appreciated.....
Old 10-16-2009, 08:49 AM #22
CayenneS2083's Avatar
CayenneS2083 is a jewel in the roughCayenneS2083 is a jewel in the roughCayenneS2083 is a jewel in the roughCayenneS2083 is a jewel in the rough
Send a message via AIM to CayenneS2083
I don't have the porsche oem leds but I have been creating some Led drl's for my car so this may help. The .1 has wires for the fogs, turn signal, and drl (city light, parking light, whatever you want to call it). It looks like the new ones just have a turning signal and a drl. My guess is it should be as easy as wiring that and leave out the fogs. You will probably need to add in a resistor for the drls. I also noticed that on the .2 the lights dim when you turn on your head lights. If that's the case their may be a relay built in that would have a seperate wire which you would probably hook up to the headlight power.
_______________________
2008 997 C2 (Oct. build)- Carrara White, Black int, yellow seatbelts and gauges, gt3 front, black sport design wheels, yellow calipers, AWE Cats, AWE tips, pse hack mufflers.
Old 10-20-2009, 02:16 PM #23
akshon
Hi akshon,
kind regards Tim
I can give you my wiring diagrams from porsche but its wrong!!
So i guess its useless but a competent electrician can figure it out.
Old 10-21-2009, 04:13 AM #24
997t's Avatar
Drl conversion
Hi Akshon, i have found an official porsche mechanic to do my rewiring at a cost of £125, he is a bit secretive and tells me pins in the control unit have to be altered, will see how he does it tomoro and post findings, so now only 24 hours till my drls work,
Old 11-02-2009, 09:06 AM #25
997t's Avatar
Finally Converted to Gen2 Drl's.
Hi guys just a quick note to say i have finished my front end conversion to gen2 and it looks awsome. as my car is a 4s the front grilles(997 505 563/4 05 9b1) are titanium and this looks really good against basalt black. A mechanic from an OPC converted my loom for me and charged £250 ($410), it took him about 20 minutes to do, when you turn ignition on the front leds come on, then when you turn lights on they dim , however if you want them really bright again just put on the foglight switch. only problems i had were the headlight washer units (997 628 163 01)are different on a gen2 and the mk1's cant be retro fitted, and also the centre duct surround (997 505 541 03 01c) also needs an additional air deflector to deflect the air to your rads, porsche part is called air routing (997 575 141 04 1c), even the dealer didnt know i had to have this, all in all well worth the hassle, car is going in next week for the rears to be done which as you guys know is really straightforward, well at long last its done
Regards 997t
hilar ioush ilarious
Old 11-02-2009, 09:13 AM #26
rvhpno80's Avatar
Smile
[quote=997t;2603963]Hi guys just a quick note to say i have finished my front end conversion to gen2 and it looks awsome. as my car is a 4s the front grilles(997 505 563/4 05 9b1) are titanium and this looks really good against basalt black. A mechanic from an OPC converted my loom for me and charged £250 ($410), it took him about 20 minutes to do, when you turn ignition on the front leds come on, then when you turn lights on they dim , however if you want them really bright again just put on the foglight switch. only problems i had were the headlight washer units (997 628 163 01)are different on a gen2 and the mk1's cant be retro fitted, and also the centre duct surround (997 505 541 03 01c) also needs an additional air deflector to deflect the air to your rads, porsche part is called air routing (997 575 141 04 1c), even the dealer didnt know i had to have this, all in all well worth the hassle, car is going in next week for the rears to be done which as you guys know is really straightforward, well at long last its done
Regards 997t
well mine has been done as well, it cost me a pretty penny, but one of the board sponsor A.I design was able to do it for me, i will post day and night pic tomorrow. Thanks for all the info 997t, but A.I was able to do it without cheating with your notes.....I appreciate everyones help..... standby for pic by tomorrow....
Reply
Tags
911, 996, 997, cayenne, conversion, daytime, facelift, fog, kit, led, light, lights, porsche, running, turn
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
