Need help! Not sure which fuse to replace on my '06 997 S
Old 01-23-2012, 07:33 AM
Need4Speed12's Avatar
Need4Speed12 is on a distinguished road
Was wondering if someone can point me in the right direction to replace a fuse. The outlet in the center console and the other outlet under the glove box no longer has a power current going through it. I suspect its the fuse but when i look at the fuse box, i have no idea which one it could be.
Does anyone have any idea which one it is?
Thanks and appreciate your help in advance!!
Old 01-23-2012, 07:43 AM
TT2911's Avatar
TT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really niceTT2911 is just really nice
If you have an owners manual go to the section on fuses. It shows what each fuse controls and where it is locared in the fuse panel.
Old 01-23-2012, 10:42 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Fuse diagram booklet is also attached to the inside of the fuse panel cover. Tool in included to help remove the small sized fuses. Will be a couple extra fuses in various sizes on the panel, to limit the need for a trip to the parts store. Keep in mind the fuses aren't supposed to blow unless something is amiss so if replacement doesn't set it right you'll need to have it checked out.
Old 01-23-2012, 01:35 PM
na011's Avatar
na011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nicena011 is just really nice
Plugging the air pump or other high wattage users into the foot well plug will cause the fuse to blow.
Old 01-23-2012, 02:29 PM
crazycarlitos's Avatar
crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !crazycarlitos Is a GOD !
i'd like to know as well since i have the same issue.
when i looked at the fuse diagram previously, i couldn't pinpoint the exact fuse to change.. then i forgot all about it.. til now. LOL
Old 01-23-2012, 04:04 PM
Thanks for everyone's info. The booklet in the fuse panel is missing, do you know where and/or how I can order a replacement fuse manual?
Old 01-23-2012, 04:27 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Does this help?
Old 01-23-2012, 04:59 PM
Dadio's Avatar
12 volt sockets are fuse F8. Cigar lighter is F10. I love a good mystery.
Old 01-23-2012, 05:05 PM
Dadio's Avatar
Sorry, row A Fuse 8 and row A fuse 10. Row A is top most row of fuses. Fuse 8 is 7.5 amp and fuse 10 is a 15 amp fuse. Gave you both just in case.
Old 01-24-2012, 07:12 AM
Thanks guys for all of your help. I will check it out tonight and give you and update.
Old 01-24-2012, 05:01 PM
I found out which fuse slot is having the issue. Its slot A8. I put in 3 different fuses (7.5) and they all pop (short out) the moment i inserted the fuse. Is this something that is easily diagnosed or should I take my car in to get checked?
Old 01-24-2012, 05:40 PM
AP 997S's Avatar
A8 is just the plug socket. It protects the plug in the passenger foot well and in the console. I'd check to see if something is wedged or stuck inside that is causing the short. Did you have something plugged into one of them before you noticed the lack of 12 volts?
Use a flash light to see is something metallic is inside the plug causing it to short out. Might be the actual plug itself. You need to do some close examination and if you can't see or find anything contributing to the short you'l have to pay someone else to find it.
Old 01-24-2012, 06:42 PM
na011's Avatar
Also check and see if the socket got twisted/rotated when a plug was removed by it being twisted.
Old 01-25-2012, 07:43 AM
AP 997S - I checked that out this morning and couldnt find anything inside or around the sockets that could be causing the shortage, man, sounds like im going to have to take her in...
na001 - appreciate the info, will check that out tonight and see if that can/will resolve the issue *crossing fingers*
Old 02-18-2012, 07:24 PM
jcrystal23's Avatar
jcrystal23 is on a distinguished road
As always, great advice.
Quick Reply: Need help! Not sure which fuse to replace on my '06 997 S
