100% invisible radar detector
Old 03-03-2013, 02:33 PM
MMK110464's Avatar
MMK110464 is on a distinguished road
Originally Posted by gasongasoff
I got the smartradar recently. Removed the bottom shell of the unit and embedded it into the passenger side sun visor. 100% hidden except for a small wire at the sun visor hinge that you can't see and the control unit mounted on the backside of the rear view mirror. The display is embedded inside the mirror (similar to the photo above).
Could you please post pictures?
Old 03-03-2013, 08:01 PM
deckman's Avatar
If you want stealth get the 9500ci. Unlike some of these others ones being discussed this is a known high performing unit. The very first thing it must do is provide early warning that is reliable. Otherwise why bother.
Old 03-03-2013, 08:08 PM
deckman's Avatar
One other thing - no windshield unit protects you from laser. They only inform you as you are being lit up, and that you should pull over to receive your ticket. You need a laser jammer to protect you. Laser Interceptor is best for that but he 9500 does good enough since you need the concealed install.
Old 03-03-2013, 11:39 PM
Macster's Avatar
Originally Posted by gonzo__007
All,
Looking at a radar/laser detector that will be 100% invisible. So obviously, that removes all windshields mounted radar as they are very visible.
Installed radar is the way to go. BUT, all of them need a control module and a display module. So again, not 100% invisible.
The only product I found that could match my needs is the Iradar S200R: https://www.cobra.com/detail/index.cfm?nPID=318
It is a installed radar/laser detector and display/control unit is the Iphone. Brilliant !
But reviews on Iradar mention it’s one of the worst products on the market.
Anything on the market working the same way as the S200R (installed, and display/control unit is the Iphone)
Ain't going to happen. The radar detector emits a signal that radar guns -- and other radar detectors can pick up.
My V1 picks up other detectors. I get a kick out of id'ing a big rig with a radar detector on board and using the CB radio to let the driver know I know...They are surprised. And thankful. IIRC for a big rig driver a radar detector is a big no no.
If you drive in an area where radar detectors are illegal just take the thing down and put it on the floor behind the passenger's seat. Drop and old banket over it.
if you can have a radar detector mount it up high to the left of the mirror and let it help protect you. Most cops don't notice the thing or if they do they don't say anything. The only time I had any trouble was when a state trooper pulled me over and warned me about where I had the thing mounted and told me where it should be mounted and if I refused to move it or take it down he would confiscate it. I took it down until I was out of the state (AZ).
Old 03-04-2013, 02:06 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Is that signal the detectors put out required by federal law in the US to allow states that outlaw them a way to detect them?
I ask, because a radar detector has absolutely zero reason to be emitting any sort of signal. The detector should be totally passive and shielded to not let any RF noise out from the circuitry.
Old 03-04-2013, 02:43 PM
Maturola's Avatar
Maturola is on a distinguished road
No, this is NOT required by law, it is just the nature of the divice. RDD (Radar Detectors Detectors) are based on picking up emissions that are generated by those receivers (local Oscillator used to generate the base frequencies). As you can imagine, more expensive devices expend more time testing and use higher quality components to minimized these emissions making it less detectable.
Old 04-23-2014, 12:01 PM
pors968's Avatar
pors968 will become famous soon enoughpors968 will become famous soon enough
Maciek,
Can you please post some pics? I like to see how you installed near mirror.
Thanks,
Originally Posted by Maciek.
Installed my Beltronix above left half of the back mirror, hidden behind factory, 3' wide tint of the windshield. Totally invisible from the outside. Only way you can see it is when you stick your had inside the vehicle through the side window and look up. Never happened so far! This setup saved me many, many times in last 15 years. Can take some pictures if interested, Drive safe, Mike from Brooklyn, NY
Old 04-24-2014, 05:18 AM
Ran ran's Avatar
Ran ran is on a distinguished road
K40 with two diffusers under front bumper cover and a rear detector under rear bumper cover - only two LEDs inside car that are not usable unless lit up and a small wireless remote for control
Works like a charm but almost 3 k installed
Old 04-24-2014, 05:19 AM
Ran ran's Avatar
Usable - visible
Old 04-24-2014, 07:13 AM
eldertec's Avatar
eldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to beholdeldertec is a splendid one to behold
Originally Posted by Ran ran
K40 with two diffusers under front bumper cover and a rear detector under rear bumper cover - only two LEDs inside car that are not usable unless lit up and a small wireless remote for control Works like a charm but almost 3 k installed
Love my K40.
Same system as above.
Old 04-24-2014, 01:24 PM
Minok's Avatar
All,
Invisible radar is possible by mounting sensors behind bumper covers, but that does reduce sensitivity a bit. May not be an issue.
Laser detection, however is not possible an be 100% invisible. Laser is light energy that must be seen by the sensor, and for that to happen, an eye could also see the sensor.
You can mount laser sensors in places that make them much less likely to be spotted by anyone not trained in knowing where to look. But that also reduces the effectiveness.
The ideal laser sensor positions would require integration of a new scale:
Integrate sensors inside the headlight units (and put jammer emitters there as well if thats where the user wants to go). And behind the license plates, with a small hole drilled to allow viewing out - and coating the sensor with some material that mimics the license plate look where the hole is to make detection 99% unlikely.
It is doable to a highly unlikely detection rate, but would require great effort and customization to achieve. Just not at 100% undetectable.
Old 04-24-2014, 07:04 PM
mto's Avatar
mto
mto is offline
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Originally Posted by eldertec
Love my K40.
Agree. Superior customer service too.
Old 05-06-2014, 12:44 PM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
i know this is old but pics please
Old 05-06-2014, 02:30 PM
Squat's Avatar
Love my K40.
except in a RD banned state you will get nailed if they are on that kick.
Old 06-19-2014, 04:58 PM
bernard.barbour's Avatar
bernard.barbour will become famous soon enoughbernard.barbour will become famous soon enough
Originally Posted by Burg Boxster
Regardless of which way you go...
Do yourself a HUGE favor and pick up a cheap/used/broken throw away detector too. Put it in your glove box or door pocket. Then when you get pulled over b/c a detector detector snags you, you'll have a sacrificial unit for the offering. Otherwise you'll pay a hefty fine AND lose a good detector.
Super good advice. I had a top of the line Escort taken many years ago back in Virginia, not a nice day! From now on I will carry a sacrificial detector in the door pocket, lol. Thanks
Quick Reply: 100% invisible radar detector
