My 997.1 Carrera2 GT3 Front and Rear Bumper conversion.
Old 11-12-2013, 04:07 PM
Xander's Avatar
Xander is just really niceXander is just really niceXander is just really niceXander is just really nice
Originally Posted by carrera997re
Looking good X. Its funny we both got the kit at the same time and both were delayed and my cars at the shop as we speak haha.
It takes time to make this stuff look that good!
Originally Posted by Mr. Meister
Looking great, homie!
Thanks!
x...
Old 11-13-2013, 07:56 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Hey X did you run into any problems closing the trunk lid? Mine seems like it needs to shave down where the lid meets the bumper so the lid can lock close.
Old 11-13-2013, 01:40 PM
sleek-sam's Avatar
sleek-sam will become famous soon enough
When I did my rear GT3 conversion, I also replaced the top bracket that the 4 or so upper screws go into.
Old 11-13-2013, 02:43 PM
Xander's Avatar
It's a little tighter, on the front I was able to move the bracket down a bit, I might try something similar in the back.
X...
Old 11-13-2013, 03:23 PM
I saw that bracket kinda looks like a steel plate did you remove that?
Old 11-13-2013, 08:59 PM
sleek-sam's Avatar
I replaced it. I used an oem 997.2 gt3 rear, so I ordered the proper upper bracket/mount
Old 11-14-2013, 03:35 AM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
excellent mod...
Old 11-14-2013, 09:03 AM
Xander's Avatar
On the front there are 3 bolts holding it on, but the holes are slightly elongated so you can move it down that 3/32 or so that it needs to go down.
On the back I haven't looked at it, but I'll figure something out when the car get back from the body shop.
X...
Old 11-14-2013, 09:34 PM
cl997's Avatar
cl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to beholdcl997 is a splendid one to behold
btw, NICE Garage. Love the hoist.
Old 11-17-2013, 11:08 PM
911bob's Avatar
911bob will become famous soon enough911bob will become famous soon enough
working on the same conversion. what bracket are you talking about?
Old 11-18-2013, 02:11 AM
kkswow12's Avatar
Originally Posted by Xander
So Fitment on the bumper was great, but there are a few things that needed some adjustment.
First off the heat shields under the bumper cover, and the brackets that hold them on, won't fit under the GT3 Bumpers because of the "vents" in the side of the bumper.
I don't have any pictures of what I cut up, but you can make it work.
The other part about mounting the bumper that doesn't fit 100% is the bottom mounts at the wheel arch. The GT3 one is about an inch lower. Not big deal.
Now on to the "big" issue... the exhaust. I wanted the Center exit exhaust, but obviously that isn't easy. After checking with others and what they did, I decided to try and keep the stock cats, instead of dealing with a light on the dash, or how to eliminate that. It seemed like others have tried, but none with an "easy" fix. Plus I am in NY state and get OBDII scanned for inspections.
I have a local guy that does pretty damn good exhaust work, so I thought I'd see what he could come up with. I bought some Magnaflow mufflers that have the "in" and "out" on the same side.
Here is the 90% done result... (just need to finalize the tips)
Sorry about the carp phone pictures. I know it's not easy to see everything, but you kinda get the idea. It's run similar to the OEM ones, but the piping keeps going past the "side" exits and goes to the center and out.
That's all I have for now, off to paint with it, and then put it all back together and put the final touches on the exhaust tips and it's respective heat shield.
X...
hey X, which headers are you running?
Old 11-18-2013, 08:56 AM
lazyseoul's Avatar
lazyseoul is on a distinguished road
can't wait to see it painted!
Old 11-18-2013, 10:20 AM
Tmainevent's Avatar
Tmainevent will become famous soon enough
Nice work! Now let's see more pics of the garage---nice set up in there
Old 11-18-2013, 07:08 PM
Xander's Avatar
Stock headers and cats. I didn't want to run into any Check Engine Lights for removing the cats.
X...
Old 11-18-2013, 07:43 PM
sleek-sam's Avatar
Rear upper bumper mount. It's the top bracket that has 4 screw that attach the bumper at the top center under the deck lid. My stock bracket did not allow all the screws to go in, so I used the gt3 bracket. I'm running an oem 997.2 gt3 bumper, so I am not sure if you need it for 997.1 gt3 rear
Quick Reply: My 997.1 Carrera2 GT3 Front and Rear Bumper conversion.
