Go Back   6speedonline.com Forums > British > Aston Martin
Aston Martin DB7, DB9, Vantage, V8 and Classic models
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-08-2009, 11:32 AM #16
SonicKrack's Avatar
2007 Aston Martin V8 Vantage
My Garage
SonicKrack will become famous soon enough
Send a message via AIM to SonicKrack Send a message via MSN to SonicKrack Send a message via Yahoo to SonicKrack
Is the O2 sensor covered by Manf. warranty? I am assuming that the cats need to come off, for that I need a garage with a lift and tools... which I don't have. My 24 months inspection is due, so I guess I will have them change it. Thanks for everyone's input.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
LEV
2003.5 ///M3 Gone but not forgotten
2007 Aston Martin Vantage
2005 X5 4.4i
Old 10-08-2009, 11:59 AM #17
Ray Portilla is on a distinguished road
Emission System Service Required
The dealer change them for free because i was instaling the N400 Intake kit and Regular service but i think you should try with any shop that has a lift , and with regular know-How you should be able to fix this.
2006 Aston Martin V8 Vantage/AM Power Upgrade/Tubi.
2008 G55 AMG.
Old 10-08-2009, 12:13 PM #18
SonicKrack's Avatar
My Garage
Ray,
Thanks for the info. I will get the sensors hopefully by mid next week and get it on a lift.
LEV
2005 X5 4.4i
Old 10-14-2009, 12:41 PM #19
acabrera's Avatar
acabrera is on a distinguished road
Update...
So, it's been over a week and the engine light is still on. My AM guy did recommend bringing it in for a look but I haven't scheduled anything just yet for heading to Orlando.
Basically, here's where we are:
  • The car is still running just fine
  • I have been driving it both aggressively and conservatively for the last 10 days
  • Worried? No
  • Annoyed? Yes
I will keep you all posted when something changes. Stay tuned...
2006 AM V8 Vantage (Tungsten Silver)
Old 10-14-2009, 12:46 PM #20
Stuart@RSC's Avatar
Stuart@RSC is a jewel in the roughStuart@RSC is a jewel in the roughStuart@RSC is a jewel in the rough
Quote:
Originally Posted by acabrera View Post
Update...
  • Worried? No
  • Annoyed? Yes
Have you taken a look at your catalysts? The OE items are pretty restrictive and not that good at dissipating heat. I have seen a few of them that have overheated and broken down the matrix inside. You can usually tell from the heat ring around the outside of the cat. Other than that I think Lambda sensors might be the culprit.
"If everything seems under control you're just not going fast enough" - Mario Andretti
Drop a cog & floor it!
Old 10-14-2009, 01:03 PM #21
SonicKrack's Avatar
My Garage
Same scenario as Acabrera. I will be getting the Portable Diagnostic device tomorrow and will see what the dilio is. Tried driving it hard and normal, same poopoo. And yes, it's annoying... The problem is that I have 6 inches of snow outside, no way I can get it to Calgary. The sucky part is that I am about ready to pull the triger on a Maserati GT...
LEV
2005 X5 4.4i
Old 10-14-2009, 01:47 PM #22
acabrera's Avatar
Quote:
Stuart,
Is this something that can easily be checked without a lift?
Old 10-14-2009, 03:16 PM #23
JeffRB is on a distinguished road
Did any one try to purchase the OBD2 portable diagnostic tool, as I did (see my recommendation earlier in this email string). Once I reset the emissions warning lite (wipes it off the ECU); I have had no re-occurance yet (fingers crossed). I took it out for a drive last weekend, really hammered it (awesome acceleration and sound with RSC setup), and no warning lite for emissions went off.
I figure that this can happen as a random occurance (even though it should not).
I highly recommend the OBD2 diagnostic tool. I carry it in the Aston trunk (its comes in its own case) in case of a re-occurance. It literally takes 2 minutes to clear the code and reset the ECU. Much better than the hassle of going to the dealer for the reset (unless your O2 sensors or cat is bad).
Jeff
Old 10-15-2009, 01:08 PM #24
Stuart@RSC's Avatar
Stuart,
You could do it without a lift but you'll still need to jack the front end up on axle stands.
Old 10-15-2009, 07:06 PM #25
SonicKrack's Avatar
My Garage
I got the Innova 3150 today, hooked it up and gave me 2 codes. First one was the temperature in some kind of relay and to my stupidity I pushed the eraser which performed a reset on the Car's computer... I wasn't able to see the second code but I will take the car out for a short ride and see if the maintenance message comes back. So to make things clear, the OBD2 tool did clear out the message Best investment ever !!!! I will go and do a moving diagnostics of the vehicle in a bit and leave some feedback.
LEV
2005 X5 4.4i
Old 10-15-2009, 08:19 PM #26
SonicKrack's Avatar
My Garage
Just got back from a 20 mile drive. Did some normal driving and some hard as well. No codes popped up, I guess will see how it behaves on longer trips.
LEV
2005 X5 4.4i
Old 10-16-2009, 01:55 PM #27
acabrera's Avatar
Update...
I have some good news! I was making my way onto a highway earlier today and all of a sudden, the engine light went away.
It happened while I was accelerating so I'm not sure if that is what triggered. It could have been the fact that it was only a few minutes after starting it up that allowed the internal tests to reset the code.
I've been driving the car for a few hours since then and everything appears to be fine.
Old 10-16-2009, 05:01 PM #28
SonicKrack's Avatar
My Garage
Well,
That is some great news!!! I hope it stays that way...
LEV
2005 X5 4.4i
Old 10-22-2009, 11:35 AM #29
P-Gunna is on a distinguished road
the same happened to me and I was told to tighten the gas cap. the light went away after a few starts but is back again!
______________________________________
09 AMV
07 Mercedes CLS 550
06 Infiniti G35 (sold)
07 Yamaha R1 & 02 Suzuki GSXR-1000
Old 10-22-2009, 12:19 PM #30
Holson's Avatar
Holson is on a distinguished road
pull the codes
mine was p0133 or something like that, slow response o2 sensors. replaced front (pre-cat) o2 sensors and so far so good
Reply
Tags
6g339f472aa, aston, car, cycle, drive, emission, emissions, light, martin, nys, reset, service, symbol, system, vantage
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
