Go Back   6speedonline.com Forums > British > Aston Martin
Aston Martin DB7, DB9, Vantage, V8 and Classic models
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 10-09-2009, 08:14 AM #16
jaymoney's Avatar
jaymoney will become famous soon enough
So the devil inside me has to ask; Have you given any thought to wheel and pinion plus supercharger? I would think that changing the ratio plus adding 140HP would make the Vantage a very nasty beast.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 10-09-2009, 08:34 AM #17
AstonAficionado's Avatar
AstonAficionado is on a distinguished road
Quote:
Not sure if you're asking me, jaymoney, but I think the gearing change would not be necessary if you went with FI and might even be overkill. This was discussed briefly in Tahoe M3's thread:
Gearing!
Also, it may depend on the type of SC (e.g., screw vs. Roots).
Old 10-09-2009, 12:57 PM #18
XJRS Owner is on a distinguished road
Quote:
Originally Posted by AstonAficionado View Post
Is there anyone else interested in changing their final drive ratio? It seems to me that this mod would likely do more to address the lack of low-end torque and its effect on acceleration than many of the other mods discussed on this forum. Am I missing something here? I'm surprised by the apparent lack of interest.
Here's why...
Who is going to install the ring/pinion set for you? Do you have any idea what that's gonna' cost? It'll probably be another $5K on top of the gearset at $6.5K. Ring/pinion install and set up doesn't sound like rocket science, but it is black magic. When the thing starts whineing like a mother you aren't gonna' be too happy. Honestly, I'd much rather bolt something on for more go, than to rip into a diff. This ain't a Chevy (fortunately/unfortunately).
Old 10-09-2009, 01:30 PM #19
Quote:
Originally Posted by XJRS Owner View Post
Here's why...
Wow, I didn't realize this was such major surgery. Assumed it was merely a matter of removing the old gears and replacing them with the new ones. Looks like some investigation as to install is warranted. Thanks for the heads up.
Old 10-09-2009, 03:07 PM #20
Stuart@RSC's Avatar
Stuart@RSC is a jewel in the roughStuart@RSC is a jewel in the roughStuart@RSC is a jewel in the rough
It isn't a major surgery. You need to replace the Crown Wheel and pinion with the new gears. Any time you do this you have to check your tolerances and shims but it isn't exactly rocket science. The critical aspect of it is the gear cutting and original geometry because the gears will wear very quickly if they don't mesh correctly.
The company which will be making this for us runs a number of GT2 race cars and uses full in-house rapid realisation prototyping facilities. They make a number of components including gearsets for F1 teams so this is comfortably within their engineering capability.
"If everything seems under control you're just not going fast enough" - Mario Andretti
Drop a cog & floor it!
Old 10-09-2009, 03:11 PM #21
Stuart@RSC's Avatar
The devil inside me is way ahead of you and suggests that anyone who accomplishes both should start buying up Yokohama shares like they're going out of style.
Old 10-09-2009, 04:57 PM #22
Before you run off half-****ed and buy a set of gears for a whopping $6.5K, you better call your local AM dealer and ask him how much labor for a ring gear/pinion replacement. He should be able to give you a ballpark to drop the entire rear subframe with diff/trans, separate the diff, remove/replace gears, set them up, and then put everything back together. Don't have a heart attack
Old 10-09-2009, 06:55 PM #23
Stuart@RSC's Avatar
You're right... it's a Ford.
Old 10-09-2009, 06:57 PM #24
Stuart@RSC's Avatar
I'm guessing you'd like to be removed from our mailing list no? Is there anything you don't feel negative about?
Old 10-10-2009, 11:00 AM #25
alevine's Avatar
alevine
I have installed ring and pinion on a few cars and I was always very satisfied with the results. It totally transformed a C5 Corvette I had and made the car a wild beast! I would be interested in this but I don't have the stones to do it on an Aston until I hear feedback from others. I'm sure the results would be awesome on this car too. I like that groups like RSC are exploring ways to further the enjoyment of these beautiful cars.
Adam
2001 Acrtic Silver/Black 996 TT-sold
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 10-10-2009, 11:13 AM #26
Quote:
Just like to see a little 'full disclosure'. Some people know nothing of a ring/pinion change other than in a Ford or Chevy. If you are gonna' ask for takers on a $6.5K gearset, the least you can do is provide a labor estimate from your nearest AM dealer to make the swap. This is a big job on an AM, don't kid anybody about that. And you can pretty much guarantee that the AM dealer isn't gonna' warranty any of his labor if you don't like the result (like excess gear whine) since they aren't AM approved parts.
Sorry you think this means I am negative about everything. Just being realistic. At least with a bolt on SC the work can be accomplished by a competent custom speed shop (presumably) since you don't have to take part of the drivetrain out.
Old 10-10-2009, 09:36 PM #27
Quote:
Originally Posted by bubba View Post
You could come really close to the actual drive ratios of a 4:11 set by simply installing lower profile (-1 series) tires. It might look a little strange, but it would accelerate exactly the same.
I decided to go with the wheel/pinion set. I installed some 16" wheels on the back for the time being while I wait for the set to be developed. The car is much quicker now, and looks sweet!
Name:	Small wheel Aston.jpg
Old 10-11-2009, 04:50 AM #28
Stuart@RSC's Avatar
No worries. We don't actually have a product anyway but are trying to respond to customer demand by investigating interest.
Old 10-11-2009, 11:01 AM #29
stearnsn is an unknown quantity at this point
It would be nice to find out if the rear end was sourced from a Ford or Jaguar part. You can buy Ford racing ring & pinion sets from Ford Racing for under $200.
ie:
http://www.steeda.com/products/ring_pinion_sets.php
I doubt AM wants to share all the secrets with us, or the aftermarket, though. Someone will have to tear one apart.
07 Vantage, AM suspension upgrade kit, AM power upgrade kit, Quicksilver Supersport cat back exhaust, Brembo 6 piston front brakes.
Old 10-11-2009, 06:55 PM #30
SonicKrack's Avatar
2007 Aston Martin V8 Vantage
My Garage
SonicKrack will become famous soon enough
Send a message via AIM to SonicKrack Send a message via MSN to SonicKrack Send a message via Yahoo to SonicKrack
You are a riot man!!!!!
LEV
2003.5 ///M3 Gone but not forgotten
2007 Aston Martin Vantage
2005 X5 4.4i
Reply
Tags
60, 911, 993, crown, improve, kit, mesh, miami, pinion, porsche, real, ring, set, turbo, upgrade, wheel, world
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
