Glass key for 08 V8V
#31
Who can program all the features to a new key: The dealer is the only one that can program all features
Can I program the new key myself to just start the car: Yes but this will require 2 already programmed keys to the vehicle(there is a Ford procedure that isn't to hard). BUT If you only have 1 key programmed to the vehicle, dealer is the only place that can get you a second new key programmed to start the car.
Can I program the new key myself to operate the locks: NO, there is nothing you can to program the key to unlock/lock/open trunk, this is only done by the dealer
Can I swap the internals of my plastic key to the new glass key I bought: Yes, you can swap the circuit board and chip to the glass key and thus the glass key will operate(vehicle will think it's the plastic key that is already programmed), but you will now have a inop plastic key.
#32
You need 2 already programmed keys to program a new key to start the car..or just use the AMDS for both with only 1 programmed key available.
Every where will cost different, but don't be suckered to pay more than the 1 hour charge..also depends if your doing a service at the same time, cost can lower for the programming..again depends on the dealer near you
#33
When you have a only a remote(new or old types) to program, the key code is supplied in the plastic package with the remote(white sticker on the plastic package), with out these remote key codes the remote is useless and you will have to order a new one.
#34
When you have just a manual key to program, the dealer gets the code online, you cannot get this code.
#35
You may have the wrong key type. For US and Japan the keys are 315 MHz, Keys for Europe are a different frequency. I bought two of the european keys from the UK. When I took them to the dealer to get programmed they would start the car but not unlock it or the other way around. Now I have to keys I need to sell to someone in the UK.
#36
#37
No..if you have a 2008+ Aston..DB9,DBS,Vantage..and you only have a plastic key. You can buy a glass key from dealer..etc, and you can have the glass key programmed the work just like your plastic key does for locking/unlocking/starting..
Thxxxxx~!
#38
Be advised nothing will work to protgam the key buttons to unlock/lock, this operation is done by the dealer
Don't take your time, you have like 10 seconds..or something around that to perform all 3 steps
#39
Start car with programed key 1, turn off and remove key, insert second programmed key and start car, turn off and remove key..now insert the non programmed key and start the car...DONE!
#40
I've never had it not work when I have 2 already programmed keys to the car and 1 non programmed key...I start the car with both already programmed keys then right away I start with the non programmed key..and it starts no prob after with that key once that method was done
#41
pretty complicated stuff on this thread ... glass keys, plastic keys, emotion controls, key fob controls...etc...
any advantage to having the original setup? put the key in, turn it, push the start button? be done with it, and go on. I've always thought more simple = less chance for things to break. dunno...
#42
My wife bought me a glass fob as a present. We unwrapped it, I went to work and she threw away the wrapping. I have two plastic fobs for this car.
Hate to be dense, but do I understand correctly that I will now never be able to open the trunk and the doors with this new glass fob, just start and run the car? That is, the dealer cannot program this glass key to do everything without whatever number code was on the plastic bubble wrap?
#43
Irish,
Without the numbers in the package u are in possession of a very expensive paper weight...BUT there is a solution, just it'll cost u a bit. U can program the new glass key to start the car with no cost to u if u have 2 already programmed keys, however just like u understand the buttons on the remote will not operate at all without those magical numbers that are indeed a pain in the a**
Solution: u have to buy 1 new remote key for a 2005+ Volvo S40, keep the package!!(or a plastic Aston remote, which ever u can source cheaper) Take the Volvo remote(or plastic Aston remote) and ur glass remote apart..swap the internal circuit board..bring the glass key and Volvo package that has the programming numbers to a Aston dealer..they can now program ur glass remote to function like it should..u don't trust urself to take apart the remotes, not a problem, he dealer can take care of it when they do the programming..takes 2minutes to swap the internals
Solution #2: if u don't mind sparing one of ur plastic remotes, u can just swap the internal circuit board from a plastic remote to the new glass key..and then u would just have to program the engine Start to the glass key
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
#44
#45
9G43-19H479-AA 315MHz(USA/CAN/JPN/Federal)
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
