DB9 V12 oil starvation, real problem or not?
I'm picking up a 2007 with the FSA165 done in Dec 2008 at 12k miles or thereabouts...am I ok?? This is a scary thread!!!
Just check the oil level and listen for any wierd noises. I have seen cars with low oil levels ( nothing on the dip sticks ) and not have any noises. Never had a complaint on anything. The cars have been back several times after this for services, with no issues.
This is all awesome information, I appreciate the detailed responses.
From this I gather a 2008-built, 2009 DB9 would already have the longer dipstick from the factory, and likely came with installed but disabled oil sensing features.
FSA 165V2 has been performed)
..for the software, DB9: A10678 Onwards, DBS: E00160 Onwards have the system available for activation, prior to those VIN's the vehicle only has the revised dipstick unless the engine is replaced recently..aka now onwards, engines now from Aston come with the new system and the vehicle software prior to those VIN's can be updated to operate the new oil level sensing
Just like your to check your tire pressures every 30days, check your oil..extra 45secs to due so is good insurance..
^^^ Sounds good mate, appreciate the advice. Do these engines cosume an avg 1 to 1.5 L or does it vary engine to engine for the most part. Figure with the revised dip stick and even with a periodic consumption as long as the oil level remains in the acceptable tick range it should indicate all is fine...
That's right...and higher mileage engine do consume also, but there aren't to many high mileage AM's out there..
Hmmmm, the dipstick of my 2009 has BD33-6750-AB on it
Further, I don't fully understand the VIN references of A00001 to A10286, or A10678 . How does that relate to the VIN of the car?
My VIN is SCFAD02E99GB11110
Thank you.
Jeff
Thank you.
Jeff
Thank you.
Jeff
Thank you.
Jeff
Thank you.
Jeff
Thank you for taking the time to explain things, and for everyone's patience with my newbie questions.
From the info above it seems Aston VINs are sequential starting with the introduction of a Model, as opposed to resetting with each model Year.
Jeff
Jeff
.. no worries, anytime I can help
VINs never reset with the year. Don't know where you got that idea. It's the same for all car models.
