- Mini Copper "Sport Aero Rod" Antenna Mod (write-up w/ pics) -
Old 01-11-2014, 05:18 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Fellow Vantage Owners,
Finally got the OEM Mini Cooper "Sport Aero Rod" Antenna in a few days ago and I wanted to do a quick write-up with high res pics to give you an idea of exactly what it looks like both up close and from afar.
Part:
Ordered the Antenna off Ebay from Plano Mini for only $35 shipped (worth every penny). The part number and packaging shown below (pics attached). The antenna is only 105mm long (roughly 4 inches for the metrically challenged). It's a perfect match to the OEM rough textured based of the stock antenna base. Ironically enough, the semi-matte finish is even an better match to the Vantage antenna base than the super long stock Aston antenna (which is more of a metallic gloss black). The angle / pitch of the antenna is also perfect. Inside the box, the shorty antenna and the larger thread adapter are included (Larger antenna adapter although nice, is not necessary for our application so you can just leave it in the box). Just for modding humor I put the stock antenna back in the Mini Cooper box for comparison sake
Installation:
Literally 10 seconds... unscrew old pogo stick, screw on stubby sport aero antenna. If you cannot do this yourself... you honestly do not belong behind the wheel of a moving vehicle
Antenna Reception:
Although it may be shorter, it appears the reception from the OEM Mini antenna is significantly better than the stock unit. Whenever I would listen to the radio on the stock antenna it would always cut in & out between stereo & mono modes. You can tell this by looking at the Dobly Surround logo come on/off in the bottom left of the radio screen. It was quite annoying and irritating. With the new antenna it no longer does this and is always in stereo mode with the Dobly surround logo always showing; both reception and sound quality have improved for the better.
Verdict:
A must for every Aston Vantage owner! I have always shied away from non OEM parts and I am aware there are non OEM parts available for less. However, none of them had the correct textured semi-matte finish as the OEM Mini Cooper S unit, and I can be rest assured that the internal antenna components of the OEM mini unit will meet the strictest quality standards of any major OEM manufacturer. Plus, I think the actual shape better suits the Aston's antenna base versus the conical shaped aftermarket antennas from Alta & etc. Worth every penny of the $35 price tag.
Enjoy,
007
(First set of pics of OEM Mini packaging, Second set of the stock antenna, Third set of the Mini Antenna Installed)
ID:	320248   Click image for larger version
ID:	320249   Click image for larger version
Old 01-11-2014, 05:20 PM
Stock Antenna Pics
ID:	320251   Click image for larger version
ID:	320252   Click image for larger version
ID:	320253   Click image for larger version
Old 01-11-2014, 05:21 PM
"Sport Aero Rod" pics
ID:	320255   Click image for larger version
ID:	320256   Click image for larger version
ID:	320257   Click image for larger version
ID:	320258   Click image for larger version
Old 01-12-2014, 06:52 AM
G50CARERRA's Avatar
G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !G50CARERRA Is a GOD !
I just installed mine. Couldn't be more pleased with this inexpensive yet functional and aesthetically pleasing mod. Great write up.
Old 03-20-2015, 02:56 PM
chogan's Avatar
chogan is on a distinguished road
+1
Just did the same on my Vantage and as 007 pointed out the radio reception is actually improved vs. stock. Had the same issue as 007 with the reception cutting out which was quite annoying. All gone now.
Old 03-20-2015, 07:45 PM
Vantagelvr's Avatar
Vantagelvr will become famous soon enoughVantagelvr will become famous soon enough
I have this Antenna on both my wife's winter VW golf and on her summer Z4 coupe .
Probably will get one for the Vantage very soon as well . Much better looking than stock antenna .
Old 03-21-2015, 02:05 PM
telum01's Avatar
Changing out the antenna was one of the first things I did when I got mine because all I could see was...
Old 03-21-2015, 03:34 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
I did the same mod last summer. It is better in every way than stock.
Ron
Old 03-22-2015, 07:22 PM
Awesome, glad the write up helped out ... Aesthetically it really is one of the best & easiest mods you can do for the earlier 4.3s
Old 07-16-2015, 04:52 PM
spikemd's Avatar
spikemd is just really nicespikemd is just really nicespikemd is just really nicespikemd is just really nice
Wondering if this carbon fiber antenna would also work. Looks like it is a direct fit for the Mini so I am thinking it should work for the vantage. The aerial sport antenna mentioned above has a flat base so I am hoping this will work. The carbon fiber may add a nice touch.
The mini aero is 3.3 inches, the carbon fiber is 3.9 inches long.
Amazon.com: GoBadges EP01 Carbon Fiber 'Union Jack' Micro Antenna: Automotive
Last edited by telum01; 05-19-2016 at 10:06 AM. Reason: Per forum rules, please do not post active links to non-sponsor vendors.
Old 05-19-2016, 10:00 AM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
don't mean to resurrect this from the dead, but this is awesome! taking a chance w/it since it's Amazon anyway and I can return if it doesn't fit.
Old 05-19-2016, 12:03 PM
spikemd's Avatar
It worked out great for me. Much nicer to have the smaller antenna. Super easy swap.
Old 05-19-2016, 03:33 PM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
Th Mini antenna swap was the first mod I did to my Vantage. Did it at the dealer when I picked up the car!
Old 05-19-2016, 03:35 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Can you post a link I can click on to see the carbon antenna? I think I need to do this ?
As far as I can see the stock SL merc uses the same antenna? Or am I wrong
Old 05-19-2016, 09:42 PM
no non sponsor vendor links are allowed. but literally, copy and paste the item name into amazon's site, or hell even google. it was $26 and change with shipping and taxes for me.
Quick Reply: - Mini Copper "Sport Aero Rod" Antenna Mod (write-up w/ pics) -
