ENgine compartment inspection plate
So, took the radiator cover plate off to get the grille off (tried to wrap and when I got to the long ones lost all patience, so I'm plasti-dipping to see if I like the look and then will get it powdercoated).
Any rate the Inspectors plate on the rad. cover plate seems to have faded a bit (sped along but a light buffing with scotch brite.
Is it possible to order these from AM with the appropriate inspectors name? Dare I ask the cost?
Chris
Chris
You can get then from Astonmartinbits here, seem to be about $160: http://astonmartinbits.com/models/5-V8-Vantage/parts/593
They can't pull the inspector by the vin but if you have the current plate you can just grab the name from there.
exc thanks!
You can get then from Astonmartinbits here, seem to be about $160: http://astonmartinbits.com/models/5-...tage/parts/593
04-28-2022 12:38 AM
