Fuel Door Issue
Old 09-02-2014, 06:07 AM
Prefurbia's Avatar
Prefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud ofPrefurbia has much to be proud of
Fuel Door Issue
I've had problems with the fuel door on my 09 Vantage having to push the button twice, then more recently multiple times, now it won't work at all. I recent had my annual inspection at Lake Forest Aston Martin and told them multiple times to make sure software is all updated and service bulletins are up to date, as well as the pedal recall. After I picked up the car, the fuel cap situation was unchanged, but I did not mention the problem either (I forgot).
Would checking the operation of the fuel door be a typical part of the annual inspection?
Old 09-02-2014, 06:43 AM
telum01's Avatar
I believe that's actually a common problem so they should be aware of it and have a fix for it.
Old 09-02-2014, 06:48 AM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
My fuel door gets stuck at times..... Probably just a minor adjustment... I need to bring mine in soon
Old 09-02-2014, 06:58 AM
karlfranz's Avatar
There is a service bulletin to address this issue. The dealer's service department should be aware of this.
Old 09-02-2014, 08:04 AM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
here ya go
Old 09-02-2014, 08:07 AM
telum01's Avatar
Originally Posted by zvez
here ya go
Thanks!
Old 09-02-2014, 08:16 AM
Prefurbia's Avatar
Shouldn't this have been looked at on my annual inspection that was not exactly cheap?
Old 09-02-2014, 08:26 AM
zvez's Avatar
If you didn't mention it, they might not have checked it, no idea what the checklist for the annual service comprises.
Old 09-02-2014, 09:10 AM
Fubar's Avatar
Fubar has a spectacular aura aboutFubar has a spectacular aura about
I have quite a few miles on my '12 and I have seen a similar issue on mine quite often. It is not that the button or actuator doesn't work but the fuel door has moved positions and is slightly stuck.
First, as a quick fix to open the door you can place a credit card between the door and car (just enough to allow the spring to pop it open). Usually this requires pushing the button with the credit card wedged in place.
Second, to fix the problem going forward (without the hassle of a service visit) simple push downward (toward the hinge) on the fuel door while it is open. There is nothing tricky here. Just give it a firm push, it only needs a small adjustment.
Hope this helps.
COBB Tuning
01-29-2022 09:42 AM
COBB Tuning
03-29-2016 09:26 PM
97GtsMonster
11-17-2015 12:38 PM
LiquidElephant
08-27-2015 06:17 PM
Quick Reply: Fuel Door Issue
