Vivid Racing : KW V3 Coilovers for V8 Vantage
We are offering special pricing for KW V3 Coilovers on all V8 Vantages 06+
PM for the best prices on this setup.
Read our write-up on this install here...
http://blog.vividracing.com/vividrac...-kw-coilovers/
Sorry to drag this up, but my contact from KW seems to think this set-up will only fit Vantages post MY08 and will not fit any V8V that did not come with the Bilstein set-up from factory...Could any one who has a earlier my06-07 confirm that this works on their cars with no modifications?
I have the variant 3 coilovers on my 2007 Vantage. Installed in 2014. No problem in fitting. With the adjustable shocks I can firm the up shocks for the track or soften them for the street.
I also installed the KW universal lift system in the front only. It will not work on the rears. The adjustment **** on the rears is mounted to the piston rod and you cannot slide the lifting component over the adjustment ****. It is also not recommended by KW as being non compatible. It did require a slight modification to work.
It has greatly improved the ride and handling.
Button in the center behind ashtray controls lift system
Front coilover with lift unit
very low ride height
