TPMS light FIXED!!! No Hack
Ok, so I had the dreaded TPMS light come on. My car is a 2008 so figured it was about time for the batteries in the sensors to die.
I read about the mods that could be done to defeat the light and I also checked with all of the local auto repair places, firestone, america's tire etc....
All claimed they could repair the problem but once I showed up there, their scanners couldn't even detect my sensors. I then inquired at the dealership and of course $1,000+ to have all 4 sensors replaced and reprogrammed.
Well i decided to tackle the issue myself. I had the sensor removed from the tire and decided to open it up. I sourced the batteries (it has 2) and started the repair. Their is soldering required and some modifications due to being unable to find the batteries with the correct arms required to reach the board. But finally got it done and all sealed back up.
Had the sensor re-installed in the tire, drove for about 5-10 mins and bam, tpms light is off and no reprogramming required. I guess as long as you still have your original sensors then they could be repaired.
Nice to have everything working the way it should be!!
thanks for the write up! my tpms light is on and don't feel like paying the $1k+ to have it fixed. any way you could post pics of where to find the wheel sensors on the wheel itself and what batteries they use?
Tire Pressure Sensor Battery Replacement: http://www.corvetteonline.com/tech-s...-tpms-battery/
How Do You Replace A TPMS Battery?
