03 Seal Grey $40000
03 Seal Grey $40000
Year: 2003
Make: Porsche
Model: 911
Price: $40000
Mileage: 54400
Color: seal grey
Location (State): FL
Transmission: Manual
Drivetrain: 4WD & AWD
1. Champion motorsports installed Tubi exhaust.
2. Champion springs with oem shocks.
3. Transmission was replaced under warranty due to 2nd gear issue and at that time I had them install 997 short shifter along with a sach's clutch. Mileage was around 30k at that time.
4. K40 built in radar
5. Champion 19 inch wheels
6. 2 year warranty left on the driver and passenger side window switch along with motor unit. Spent 2k to have it replaced recently.
7. Champion pedal set
Car has no check engine lights, no smoke, no rattles, leather seats have no rips or anything and the dash is in perfect condition.
Car can be inspected at champion or uspmotorsports in florida for any assurance prior to sale.
This is a basically a stock car and is perfect for someone who is interested in a car that is not molested or tracked. Can be modded according to one's liking. If anyone is interested, I can be reached at
drmann12@yahoo.com
https://www.youtube.com/watch?v=dPms...ature=youtu.be
Video of the car.
I had listed this car previously but ready to finally let her go now. I have lowered the price to my bottom dollar to cut the chase.
$40000 takes it.
Video of the car.
$40000 takes it.
Is this the same listing? https://www.6speedonline.com/forums/...eed-turbo.html If so why make a second post?
I have had this car since 2004. No accidents, no track abuse, never been chipped. Clean car . I welcome any inspections.
40k FIRM.
40k FIRM.
Just so everyone knows
PRE-PURCHASE INSPECTION REPORT:
Front and rear brake pads & rotors - 0.00 above 75% life, GOOD.
Rear tires below wear mark, front tires are at wear mark- recommend 4 new tires.
Front passenger side inner & outer CV axle boots cracked, require replacement.
Vehicle is equipped with Tubi exhaust system.
Engine and transmission do not show any visible leaks, GOOD.
Rear hood struts bad.
Power steering pump was low on fluid, refilled. No visible leak present.
Master cylinder reservoir has small leak of fluid, possible faulty reservoir.
Power windows have normal operation, GOOD.
A/C system has small particles coming from vents from dry rotted insulation padding.
Battery & Alternator tested GOOD.
Coolant & Brake fluid GOOD.
Thanks alot for the ppi report .
$300 to fix the inner and outer boot and there are many people selling barely used tires(90 percent) with the proper specs for $500 for rears. I also have access to stock wheels with practically new tires. That is another option. Car is a very clean like I mentioned any inspection is welcomed.
