2006 BMW Dinan M5 S2 Serial No. S20805
Year: 2006
Make: BMW
Model: M5
Price: $36000
Mileage: 82000
Color: Black
Location (State): TN
Transmission: Automatic
Drivetrain: Rear Wheel Drive
The launch control has never been used on the car. The SMG Euro upgrade lets you launch the car at 4k if desired.
I have all of the receipts from the parts and labor in a folder. Any inspections are welcome. I am willing to drive the car to any shop at your expense.
The car has been a pleasure to own and drive. The exhaust setup on this car is INTOXICATING! At 5k or 6k, the car sounds like a true F1 car. At normal driving speed, you can have a normal conversation in the cockpit without having to worry about the exhaust being to loud. But if you get on you will surely get people's attention.
This M5 is not your normal stock M5. If you are looking for a stock M5 this car is not for you.
Link for Dinan description for S2. https://pictures.dealer.com/crownbmw...40c8094629.pdf
Engine
Dinan Stage 3 software
Dinan 13mm Underdrive Crankshaft Pulley Kit
Dinan Intakes
Dinan High Flow Throttle Bodies
RPI Red Intake Scopes
RPI Oil Cooler
SMG /Transmission
Euro SMG Software
Dinan 3.91 Diff
Suspension (Complete Dinan stage 3 suspension package)
Dinan Front Carbon Fiber Strut Bars
Dinan Rear Carbon Fiber Strut Bars
Dinan Performance Springs
Dinan Front Roll Control System
Dinan Front Sway Bar
Dinan 21mm Adjustable Rear Anti-Roll Bar
Dinan MonoBall Kit.
Exhaust
Dinan Free Flow Exhaust Silver Tips
Dinan 4 Inch Resonators
Dinan High Flow Middle Racing Exhaust (X- Pipe)
Maintenance
VAC Rod Bearings at 75k
ARP Rod Bearings Bolts at 75k
Coolant Temp Sensor at 75k
Upper Coolant Hose
Seal Rings for Vanos lines 75k
Internal High-Pressure Vanos line 75k
2 External High-Pressures Vanos lines 75k
seal rings for Power steering lines 75k
Oil Change at 82k
Spark Plus at 75k
Ignition Coils at 75k
Fresh Coolant at 82k
Rear Diff Fluid at 75k
New CarboTech Breaks Front and Rear at 70k
New rotors Front and Rear at 70k
Clutch Slave Cylinder at 82k
CH11s new fluid for SMG at 82k
SMG Transmission oil at 82k
New Fill Plug at 82k
Seal Rings at 82k
Pivot Point at 82k
Retainer Spring at 82k
Throw out bearing at 82k
Fuel Filter at 75k
Fuel Pump at 75k
Miscellaneous
Upgraded Speakers with JL audio
Iphone Dock
Extra OEM Wheel with DWS Tire
10 MM H&R spacers. Front and rear.
2 pre cat sensors as spare items
Dinan Badge never installed.
Asking price $36,000 OBO. I am willing to ship the car at owner's expense. Serious inquiries only, please.
I can be reached by text or cell 615-nineone3-zero658.
