2010 Nissan GTR TSM Built 1423 WHP!
Old 09-30-2016, 04:10 AM
tricolorpit's Avatar
tricolorpit is on a distinguished road
Year: 2010
Make: Nissan
Model: GT-R
Price: $115000
Mileage: 21828
Color: super silver
Location (State): CA
Transmission: Automatic
Drivetrain: 4WD & AWD
2010 TOP SPEED MOTORSPORTS BUILT 4.1 STROKER ALPHA 12
Performance Numbers:
E85 32-33 PSI 1300 Wheel Horsepower
E85: 37 PSI 1423 wheel Horsepower
Motect On The Fly 9 Power Level Selector
Standing 1/2 Mile 203MPH to 210MPH
Performance Upgrades
Power:
-TSM 4.1 Stroker Motor
-TSM Spec Sonny Bryant Crankshaft
- TSM Spec Iron Sleeves
- Diamond Billet High compression Pistons(TSM custom spec)
-TSM Spec Callies Rods
-TSM Pro Series Race Ported Cylinder Heads
- Ferrea +1MM valve train
- Race port / polish
Race valve job
Reinforced and Braced Head Upgrade to Handle High Horsepower
GSC S2 274/274 Durations Cams
GSC Valve Springs and Retainers
GT1R CNC Oil Pan
ATI Balancer
AMS ALPHA 12 Turbo Kit
ARP Custom Aged Head Stud Kit
Boost Logic Manifold with 3rd Rail Setup
ID1300 Injectors Main
ID1725 Injectors Secondary
Fore Innovations Level 4 Fuel System
-Fore Innovations Fuel Rails
-Triple Walbro 485 Fuel Pumps
-FC3 Staged Controller 4 Gauge Wiring
-Teflon -10 Feed -8 Return
-Reusable Stainless 10 Micron Filter
Motec M150 ECU
-AMS 4 Bar Alpha Map Sensor
-Motec Programmable Autoshift (When in Manual Mode!)
-Motec Sensors
Stage 4 Shep Trans Originally had PPG gear set
Upgraded to Stage 5 Recently With Dodson Extreme Gearset and Dodson Input and Output Shafts by SPE
Promax 10 Plate Clutch
ETS Tilton Billet flywheel
2016 BellHousing Update
DSS Pro Level Axles
Hook Slot Rotors
(6)Custom Wheels Red Anodized
One Set with TOYO R888
One Set of Rear Matching With M&H’s All New
Recaro Heated Seats
2015 Updated Electronics And Backup Camera
Hard Wired Valentine One Radar Detector
Laser Interceptor Quad Jamming System
AMS Carbon Duckbill Trunk Painted to Match
Nissan Clear Corner Lights
I cannot explain to you in words or on Paper just HOW MUCH CAR this GT-R Truly is. I am selling this car and my others to Pursue Other Ventures in Life. The car hobby will end for a while. Now to describe this Beast.
It’s one thing to sell a car. Maybe it has an underlying Problem, something thats not ideal. USUALLY there is a reason aside from just wanting something else. BUT I truly Feel that NO OTHER CAR can compare to this one. It is Perfect in so many ways. I am 44 and truly feel there is no upgrade for a horsepower junk. Some may not believe but here is why:
I can jump in this car any time of day and go anywhere, in any temperature. The car ALWAYS runs cool, Engine oil Temps, Trans Temps, all stay AMAZING. On a 100 degree plus day, this car NEVER misses a beat. AC on, Oil Pressure High, Coolant Temp Low, Ready to destroy any car or bike it runs into. With 9 power Levels on Tap ON THE FLY it’s infinitely adaptable to any situation. Cruising around it can literally feel stock. Of course when you hit the gas a bit you hear turbos, and a huge rushing of air, you hear the straight cut gears in the transmission. When you roll into boost it feels like the space shuttle taking lift off! Words cannot truly even describe the feel. It feels as if it could jar your equilibrium if you turn your head! This is no exaggeration. I have only ran the car on the 1300whp setting. and also when freshening up the plugs and doing a fresh oil change with Redline 50 wt. I had a Leakdown Done just to verify numbers. Numbers were as follows COLD
Cylinder 1, 2, 6 = 2 percent in each
Cylinders 3 4 and 5= 0 (yes zero)
Leak Down Numbers do not get any better than this. AND this is with about 2500 Miles on the Build!. It’s Proven. Kinks all worked out. Tuned by Rob Harper Formerly with TSM. Needs nothing other than somebody who will respect and enjoy it. Although it has not been drag raced, only 1/2 mile. Cicio of TSM says it should be an easy mid 8 sec GT-R at over 170. And it’s one docile enough to drive daily or use as a grocery Getter.
The combination of how this GT-R looks, runs, and sounds, seems second to none when you add it all up. In all the cars that I have owned and there has been many, nothing comes close.
Most Builds of this Nature take not only a huge amount of time and money to Build, but also time ironing out the hiccups and dialing everything in. This one is “turn key ready”. Also has a Clear Bra on the whole front half of the car. There are some things which I am sure are being left out. It would Cost Between 200k and 250k to duplicate this car along with a lot of downtime. No 2 cars are alike, and thats for sure. There may be some Faster, or even Newer, or prettier. BUT when it comes to something thats Stupidly Fast, Reliable, Can be driven on ANY day, has ZERO issues, Looks ridiculous with so many upgrades. Stops on a dime. Even sounds Perfect with no drone! This GT-R stands Alone.
I am striclty Getting out of my car hobby for a while due to other family priorities. Somebody will get the GT-R of their DREAMS!! I've already sold my 2 Gen 5 Vipers, and my Harley. This is the last one.
Also, this car has never been in any fender bender and has no stories.
Feel free to call or text.
Todd 951-816-9111
I am open to any offers and will consider trades. Un modified preferrably.
Old 09-30-2016, 06:55 AM
arjayr33's Avatar
arjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond reputearjayr33 has a reputation beyond repute
nice toy and great price! glws OP
Old 09-30-2016, 10:38 AM
GCBC's Avatar
GCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond reputeGCBC has a reputation beyond repute
yeah.... but is it fast????
Old 09-30-2016, 11:08 AM
Not sure how to answer that. If you've ever been in a 1000+whp GTR you wouldnt feel the need to ask.
The car is down right brutal.
Old 10-01-2016, 03:41 PM
Turkish's Avatar
Turkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond repute
Lots of 1000+hp GT-Rs poppin up.
Sooo tempting!
Wish these things were 6-spd.
GLWS!!
Old 10-02-2016, 10:54 AM
Well they are , just not manual
Old 10-02-2016, 11:40 AM
arjayr33's Avatar
even to retrofit with a manual there's not that much available system out there to withstand the power these monsters produce. he's got a built Shep unit that's bullet proof.
Old 10-02-2016, 03:29 PM
7thsign's Avatar
7thsign has a spectacular aura about7thsign has a spectacular aura about
Hell of a deal.
Old 10-03-2016, 12:43 PM
These builds aren't cheap to build, that's for sure And building them right costs even more!
Old 10-03-2016, 07:42 PM
arjayr33's Avatar
why sellin OP? it'll be very expensive to duplicate
Old 10-03-2016, 09:40 PM
To be honest, new wife isn't into the racing scene, doesn't like loud cars and bikes, etc. wants to travel. So I decided to take a break from my hobbies for a while. Already sold my (2) 2014 dodge vipers, 2016 Harley street glide and this is the last thing. Then I'm down to just my daily driver (hellcat) and hers (m6). And an empty garage. I may get a fishing boat or something that she enjoys as well (maybe convince her to do shark fishing haha) Cars come and go, maybe good to take a break for a bit.. Still unsure!
Old 10-07-2016, 04:57 PM
Turkish's Avatar
Stop bumping!! I gotta stop thinking about this thing!!
Also, if youre ever in OC for the love of God give me a ride!
Old 10-10-2016, 07:50 PM
Lowest Gtr on the market with this extensive list of upgrades.
No trades at this price
Old 10-10-2016, 08:42 PM
turbotuner20v's Avatar
turbotuner20v is on a distinguished road
What about cylinder 5?
Cool car!
Old 10-10-2016, 09:03 PM
Cool car!
Sorry quick typing 5 was zero. Highest number cold was 2!
