FS: 1989 964 C4 - Manual - Forest Green
Year: 1989
Make: Porsche
Model: 911
Price: $46000
Mileage: 181000
Color: Forest Green
Location (State): MN
Transmission: Manual
Drivetrain: 4WD & AWD
Lots of records, some from when the car was new.
This car has 181K miles. Owned by PCA members for the past 15 years.
Email me: john.o.hull@gmail.com
Price
As is: $46K obo
Without Wheels - Minus $3K
Without Coilovers - Minus $2k
Engine Rebuild
- Crankshaft up rebuild on engine at 100K. Professionally done by Imagine Auto, Stephen Kaspar (AKA PorschePHD, Kansas City). Full build documentation.
- Custom work with 993 valve train
- Phosphate infused valve guides
- 993 Hydraulic lifters (no valve adjustment needed)
- 993 sport cams.
- K&N filter with gutted airbox (I have stock airbox).
- Primary exhaust delete with bypass pipe. It gives an awesome sound without being too loud or droney.
Recent Maintenance
- Rebuilt Steering Rack
- Rebuilt power steering pump
- Replaced transmission with a 67k mile one from LA Distmatlers
- New clutch, pressure plates and throw out bearing
- New oil return tubes
- New Hawk HPS brake pads on all four corners
- Replaced AC system from a 94 RS America
- Past owner has a paint touch up. Not full respray, but cleaned up some of the paint
- New clutch slave cylinder and hose
- New hood shocks, front and rear
- Four wheel alignment & corner balance after coilover installation by AutoEdge
- Replaced oil tank and oil line hoses
- Rebuilt pedal assembly
- New Hydraulic valve lifter (cylinder 4 intake, it only needs one)
- Spare set of Design 90 wheels
- Recent valve cover gasket change
- Oil changes every 3k with Brad Penn 20W-50
- New Knock Sensors
- New Fuel Pressure Regulator
- New oil pipe on driver side
- New tie rods
- New control arm bushings
- New Kienzle Autoradio MCR-1016 Radio
- RS Dummy fog lights
- New Speakers
- Steering wheel, both aftermarket and stock
- JRZ RS1 Coilovers
- 18x8.5/9.5 BBS LM
- Michelin Pilot Sports
- New fuel lines within the engine area
- Brand New OEM Taillights
- Fabspeed Front Strut Brace
- 993 Weighted Shift **** and Boot
Bad (Not that bad)
- AC needs recharging.
- One small door ding
- A mark on the front bumper from previous owner.
- Very slow leak from the timing chain box. So slow, I doesn’t actually drip, it just has signs of a reseal in the future.
- Penny sized surface rust spot on passenger side fender
Stack of records, some all the way from original owner in 1989
mdrobc13
04-18-2017 09:10 PM
