FS: 2013 Mustang GT - MOTOIQ Project Vehicle
Year: 2013
Make: Ford
Model: Mustang
Price: $36000
Mileage: 37000
Color: White
Location (State): CA
Transmission: Manual
Drivetrain: Rear Wheel Drive
Less than 1,000 mi on the engine, clutch, bbk setup.
$36,000
2013 Ford Mustang GT
5.0l V8 – Manual Transmission 6spd
Clean Title : 37,000 miles : Never tracked, only baseline tested
456rwhp 384tq
Factory Upgrades:
Ø Technology Package
o FORD SYNC Voice-Activated, in-vehicle connectivity system
o Steering wheel-mounted audio controls
o 6-way power drivers seat
o Auto dimming rearview mirror
3.73:1 gear ratio with limited-slip rear differential
Reverse Sensing System & Active Anti-Theft System
Modifications List:
Ø HRE
o 20x10.5 +45 HRE Flow Form FF01 in Sky Blue
Ø Nitto
o NT555 : 285/30/20
Ø Essex
o AP Racing Radi-Cal Big Brake System
§ Pro 5000R Caliper
§ Ferodo Racing DS1.11 Pads
§ Essex 2pc Rotors (372mmx34mm)
Ø KW Suspension
o KW Clubsport Coilover System
Ø Whiteline Suspension
o Front & Rear Sways
o Tubular Trailing Arms
o Upper Third Link
o Watts Linkage
o Endlinks
o Urethane Bushings
Ø Ford Racing
o Cobra Jet Air Intake
o Cobra Jet Throttle Body
o Cobra Jet Intake Manifold
o Lower Controls Arms
o Bump Steer Correction Kit
o Camshafts
o Heavy Duty Oil Pump
o Variable Timing Gears
o Blue Coil Covers
Ø JE Pistons
o JE Forged FSR Pistons (11:1) w JE Rings
o JE Pro Seal Head Gaskets
Ø K1 Techonology
o K1 Technology Rods
Ø Canton Racing
o Oil Pan (2qt Increased capacity, improved baffling)
o Surge Tank
Ø Miscellaneous Engine
o CNC Ported Head
o King XP P-Max Bearings
Ø ACT
o Performance Clutch Kit
o Pro Lite Flywheel
Ø Borla Exhaust
o Long Tube Headers
o X-Pipe
o ATAK Exhaust
Ø Work done by
o Installs : Technosquare – Carson, CA
o Alignment : Westend – Torrance, CA
o Tuning : Addiction Motorsports – Moorpark, CA
