1987 Rx7 Forged LT1 V8 Turbo(STS kit) 500whp + $8k
Year: 1987
Make: Mazda
Model: RX-7
Price: $8000
Mileage: 129000
Color: white
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
https://www.youtube.com/watch?v=yY8GSlDauZI[/URL]
Currently Tagged and Inspected till end of the year
Location Dallas Tx
Rearmount STS turbo V8 6 speed(t56)
Motor specs
10K on built motor + 129k on chasis
granny's speed shop kit
sbc 350 LT1 out of 1994 corvette
Forged Internals (Pistons), compression 9.5:1
Aluminum heads freshly built to 357 with eagle h-beam rods
Three angle Valve job
New Cam and Main bearings
New cloyes timing set + new melling oil pump
1.5 pro comp roller rockets
LT4 hotcam
Profesionally built and balanced
MSD opti and coil
42LB Bosh green top fuel injectors
Walboro 255 fuelpump
Apr bolts
lunati .040 over forged pistons
Trickflow .040 mls head gasket
Ceramic jet coating on headers
2.5 inch custom exhaust header
turbo LSD rearend
10K on motor + 129K on chassis
Rearmount Turbo
Sts kit
Turbo specs: 68-1 a/r t4 garrett turbo
Tial Wastegate 10 psi spring
Greddy Bov
Transmission
T56 out of 1995 camaro
stage 4 clutch (it chatters a bit)
Electronics
Stock working guages except speedometer
SPA design Boost/Fuel pressure guage ($450.00)
Upgraded stereo with Pioneer headunit and single sub (sounds great)
Suspension
adjustable springs with tokiko adjustable shocks
Turbo brakes + SS lines
Wheels
double staggered 18/19s
Very conservative tune at 10 psi approximately 500whp
Cons:
some surface rust on front passenger side fender and around sunroof
No Ac, orginally an AC car
For workign ac you need a braket for ac compressor and custom lines built
tune could use some refining for idle + its held up great for 5 plus years no issues. Honest Great platform well sorted build.
txt or call 214.846.71fourfour
Listing for 8k
I haven't taken it to the track. This has been more of highway toy. But for a frame of ref from a 40 roll it was tie against a 600whp gtr. The rx7 has held up great last 5 years no broken parts, I would like to keep that way : ) so no dig races. But I would imagine it would be high 11 to low 12sec car. Thanks
