2005 Lamborghini Gallardo UR Twin Turbo 6-Speed
Year: 2005
Make: Lamborghini
Model: Gallardo
Price: $162000
Mileage: 15150
Color: Blue
Location (State): VA
Transmission: Manual
Drivetrain: 4WD & AWD
-Landry Thatcher
-Landry@Aputn.com
-865-963-8248
Up For Sale is a 2005 Lamborghini Gallardo fitted in Blu Caelum Metallic with Blue Scylla/Avorio Lilium Interior. This combo is very unique especially paired with the 6-speed manual transmission. The car has a little over 15,000 miles on it and has been under the same owner for the last 8 years. This car was built by Underground Racing and has been nothing but extremely reliable and proven as of 5/1/2016 when the car went 198mph in the Wannagofast half mile event.
This car has been maintained and built by the best in the business Underground Racing and all invoices/window sticker will be included with the car. The car originally was built as a 1R package and since had further upgrades done.
Mods-
Underground Racing Custom Twin Turbo System
Custom twin billet 67mm Precision Turbochargers
TiAL billet wastegates and billet blow off valves
Custom fabricated stainless steel exhaust using aircraft quality metal
Ultra lightweight stainless steel mufflers
Custom fabricated stainless steel air induction using aircraft quality metal
Custom Air/Water intercooler system with high flow water pump
Custom ice water reservoir
High flow intercooler water heat exchanger
Crankcase ventilation system
K&N air filters
Show quality polishing on turbo compressor, intercooler and charge piping.
Custom heat shielding and high quality heat wrap
Exhaust Finish Options:high temp heat coating or polished mirror finish
High quality silicone hose
High pressure T-bolt clamps for intake pressure tubes
High quality v-band clamps for exhaust connections
Underground Racing Custom Billet Short Block
Full blue print and balanced race short block
Carrillo billet steel connecting rods
CP custom reverse dish aluminum race pistons
CP spiral locks
CP .180+ wall wrist pins
CP oil rail support
Custom steel cylinder sleeves
Main bearings
Rod bearings
Total seal TNT file fit rings
Stage 3 cylinder head porting
Fuel System
Two custom billet fuel pump hangers with high flow fuel pumps
Custom aluminum fuel rails
All Aeroquip stainless steel fuel line and aluminum fittings
Aeromotive adjustable fuel pressure regulator
Upgraded fuel injectors
MoTeC ECU
Boost By Gear
Custom Harness
Motec DBW Throttle Control
Superleggera Throttle Bodies
Tilton Carbon Race Clutch
Billet Flywheel
Billet Cover
Billet Ring Gear
Billet Output Gear
4-Point roll bar and fire system
Simpson custom race harness
Clean Title and CarFax
I am listing this for a friend and can help assist with any further information that is needed. He is only selling to pursue some new business opportunities!
Here is the latest video of the car at the Wannagofast Event.
Yes the car now has ADV.1 Wheels with Toyo R888 tires with less than 1000 miles on them. I do not have a lot of great shots with the new wheels and tires, but I will post what I got.
