You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I am not 100% sure but I do not believe so. I think the 997tt has a wider wheel. The guys in the 997 forum could probably give you a definitive answer.
Typically on a 997 (including the TT) you want a 11-12" wheel, I would imagine that these are 10" wide. Also to make these work on your wide body, car you would need spacers.
They are beautiful, but I would only put these on a 996, 986, or 987.
__________________ 2006 997 C2S Seal Gray
A few mods 2004 VW Touareg V8 Offroad Gray
Hitch, Tekonsha P3, iPod kit, Parrot 3200 18' Aluma Open Trailer
This is what I just received from Guillermo (the seller) concerning the wheels.
"Hey man,
I am not sure....I got this from the Porsche forum and sounds right:
235/35/19 fronts 51mm offset
295/30/19 rears 38-41 mm offset
I think one member has gone with a 305 in the rear though
5x130 i believe is the blot pattern
As for the fitting, my wheels WILL FIT a Cayman S since the hub is narrower by 4mm 9done by HRE factory) and will also fit all 996 Porsches."
Does this mean these wheels are not recommended for narrow body 997S?
"Hey man,
I do not think it will fit a 996 NB or 997NB can someone chime in if they know for sure?
A buddy installed cayman wheels on his 996 4s while he was waiting for his aftermarket wheels. The cayman wheels did fit on his 996 but it was not a good fit because the bolt patterns were a little different...
Here is the serial number from the wheels Front C1H19x8.5 ET51 (offset) Back C1H19x11 (HRE Shaved 4mm off the back wheel in order for it to fit the Cayman S correctly and not stick out, that is why there is no offset number)
From my understanding you should be able to call HRE directly (760.598.1960) and inquire about fitment from giving them those numbers and mentioning the shaving off of the Hub 4mm. I would rather you guys hear it from the professionals than myself on fitment.
The wheels were purchased by Ben at Wheels Boutique for their customer so they should have in their system that they sold these wheels to him.
how could it fit but not good if it is a different bolt pattern? Are you referring to the wheels not being hubcentric? Either the bolts will fit or not, the only thing in question is the offset or width.
Very interested if still selling and willing to neg. some? Where in Ca. are you located? Is pickup OK?
__________________ 2008 M6 White / Silverstone To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
20" DPE Signature Series S10 Black Matte / Chrome lip / Vorsteiner Hood and Front Lip Spoiler / Meisterschaft Touring w/ CF tips / Red powder coated calipers / Eibach Springs / RPI Scoops / BMC Filters / Rogue pulleys / Various CF parts (Still deciding)
2007 Cayman S Black / Black (Bro's car)
Needing mods.
