CD Nav Swap To DVD? Is it easy swap?
Old 10-01-2013, 06:07 AM
carlosC4S's Avatar
carlosC4S is on a distinguished road
Hi all
Sorry if this is a repetitive question but can the CD based Nav changer from my 2005 be changed by simple plug and play to a DVD based unit without any problems? If so, can VAG based units work too, they look the same?
Carl
Old 10-01-2013, 01:38 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
Carl, never heard of anyone doing that, so not sure if it is plug and play. Perhaps ask the dealer. Maybe Bentley Tech knows?
Old 10-01-2013, 06:56 PM
bentleytech's Avatar
bentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of lightbentleytech is a glorious beacon of light
never seen it done,i should think the infotainment unit might not be compatible .
Old 10-01-2013, 08:49 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
HI Carlosc4s.
I don't know the answer for your question but it might not make sense to try to improve the stock system since it is so old. You might be better off to have an iPad with 3G/4G connection or tether wifi from your smartphone.
Old 10-01-2013, 10:35 PM
You know i have thought about this and all the infotainment receives is a video signal on a fibre optic cable,it obviously has other connections but it may well work,not sure how much you can get a dvd for,it would be nice if you knew someone and could slave a unit in before purchasing.
Old 10-02-2013, 02:21 AM
carlosC4S's Avatar
Is plugging in a DVD unit likely to cause any problems if i need to revert back or will it just work, or not work?
Any idea of the VW / Audi units will be worth a short, the unit looks identical?
Old 10-02-2013, 02:24 AM
i dont believe any damage will be done,it will,like you say,either work or not.
Old 10-02-2013, 05:47 AM
Agreed, it *may* work as the head unit is only pulled the digital info data from the disc, all video/processing is handled by the head unit itself. Should cause no damage. Just am not use if the computer needs a different hardware 'driver' to operate the DVD unit versus the stock CD. Still, worth a try if you can test it for free just to see.
DVD discs are cheap, just use the 2013 BMW 2-DVD set as I do here, works great and far better than 8 to 10 CDs.
Old 10-16-2013, 07:38 PM
ducatirider's Avatar
ducatirider is on a distinguished road
Carlos, did you ever try this out?
Old 10-16-2013, 07:46 PM
Just come across this:
Anyone got any details?
Old 10-17-2013, 03:02 PM
carlosC4S's Avatar
I haven't done it yet, am waiting for the right unit at the right price, incase it doesn't work
Old 10-17-2013, 04:54 PM
Thought I should update this, spoken with a specialist, no point just swapping out the CD unit to the later DVD unit.
I'm told whilst the screen on the 04 - 06 looks the same as the 07 - 09, the functionality and control module associated are different and the DVD is not compatible with the old screen.
What a bummer.
Old 10-17-2013, 04:55 PM
I do however have a specialist who is working on something and he will get back to me. Let's see how it goes.
I want the stock look and fell and functionality with updated nav which you can actually search post codes/zip codes. - Like in the video I posted above.
Old 10-19-2013, 07:55 PM
BentleyF's Avatar
BentleyF will become famous soon enough
how much is that?
NC 996TT
03-23-2023 06:19 AM
Rguy
04-12-2020 11:11 PM
the5
10-14-2015 06:46 AM
maroli
09-15-2015 07:07 PM
sparks
09-08-2015 03:03 PM
Quick Reply: CD Nav Swap To DVD? Is it easy swap?
