Centre console slider repair
Old 05-05-2016, 08:36 PM
REDNOSEGT's Avatar
REDNOSEGT will become famous soon enough
lets hope nobody ever has this happen to them
Going to attempt to reglue maybe using 3m vhb tape or something else with good grab. they are actually numbered. its on over-engineered system in my opinion a simple wood door would have been ok not this crazy slider system with double sided tape to hold the wood pieces in.,
big thanks to Johnny hotspur for the tips to get at this part, half the battle is to get it removed if its the backseat one, the front seat one is easy. this one is the backseat one.
Old 05-06-2016, 09:17 AM
PMS's Avatar
PMS
PMS is offline
PMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud ofPMS has much to be proud of
I've been there. I agree: BAD DESIGN. When I first got my B, the rear cover would only open half way. Turns out, the stop on the bottom of the track was open and part of the assembly fell down into the cavity. Someone obviously tried to force it which caused the cross-members to detach from the membrane and fall down into the console. As you say, the cross-members are numbered and I made a new membrane (to hold them together). I then used strong contact cement to glue the membrane to the cross-members. Five years later, the fix is still holding the "roll-top" door works perfectly.
Old 05-06-2016, 07:31 PM
REDNOSEGT's Avatar
It is difficult to fit in the backseat to do any work on this car, at least that's what I find.
I did 3m vhb , removed all the old glue and I also greased the track with white grease to help the door slide easier . Seems good so far
Todd Gibbs
930 Turbo
04-09-2016 03:27 PM
ALEV8
04-08-2016 10:59 PM
unisist
Cayenne
04-07-2016 03:00 PM
Quick Reply: Centre console slider repair
