Ctek charger question
i put a brand-new battery in and have had it on every waking second for the past for 3 days . I have it snowflake mode which is evidently recommended for AGM batteries . It's still showing it's charging it is not switching to maintenance mode which would indicate full charge and just maintenance . I was curious so I hooked the diehard charger up with the charge indicator and after 20 minutes that showed full charge . That was at 2 Amps. I don't get why the Ctek won't switch to maintenance mode which indicates full charge or over 12.9v??
