| BMW //M Discussion on the BMW M1, BMW M3, BMW M5, and the BMW M6 |
Welcome to 6SpeedOnline.com! |
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
09-30-2008, 02:53 AM
M5 Dinan "Stroker" vs stock E60 M5 (vid)
'02 996TT w/X50 - Slate Grey Metallic/Black Full Supple Leather/ Carbon Fiber Trim - Wheels painted exterior color
EVOMS Stage 4 w/wastegate mod and hose kit
PSS9 w/H & R sways
EVOMS F & R tower braces
Sachs Clutch and Porsche SSK
______________________________________________
Other car: (daily driver)
'02 BMW M5 (Chiaretto Metallic/Blk full leather)
Dinan S3 S/C Performance Pkg
Dinan Stage 3 JRZ suspension w/camber plates
Dinan F & R Sways w/F & R Tower Braces
Dinan S3 clutch/flywheel & 3.45 Diff
Dinan 18" forged Aluminum Wheels w/275 RA-1's all around
Dinan SSK
09-30-2008, 03:28 AM
Thanks for the link, wow, it isn't even a comparison. Very impressive NA power, but it comes with a hell of a price tag. Can't wait to see what it puts down on a dynojet to put some questions to rest.
How much power is your SC E39 putting down?
DCT M3 - 12.1@115
09-30-2008, 01:29 PM
E39 M5 S/C'd Dinan S3......
Quote:
I must say, 'not a believer in "roller" dyno rw results when it comes to proving performance gains. At any given time, even intra-day (same car; same dyno; same operator; pre and post "pulls"); especially Dinan mods which are all developed/tested on their very expensive, custom/proprietary engine dyno; which uses fluid dynamics technology; the same type of measurement used by virtually all professional race car engine builders. These devices can pinpoint engine power output, at the crank, under an infinate variety of simulated conditions. Those engine builders don't give a "rat's azz" what rw power output is. Why?? 'Cause rw dyno's have to assume a drivetrain loss %; which can vary from car to car, gear to gear, and even different RPM levels within each gear; not to mention there's no "roller" rw dyno made that can duplicate "at speed" airflow, or be run in a 1:1 gear @ max power RPM's. The "rollers" can't handle those kinds of wheel speeds. Almost all professional race engine builders use Dynapak dyno's, combined with their proprietary mapping software, plugged into the car's engine control unit, for fine tuning. But that's it.
All that said, it's decidedly impractical for street car owners to test their power gains by taking their cars to a race car engine builder, and paying big $$$ for engine removal/testing/re-install. So, we're left with what is, at best, a power output "educated guess" on "roller dyno" testing; translating via drivetrain loss "standard" (but highly variable) assumptions, to actual engine output (and most people know that base factory engines can vary in power output by as much as +/- 5%; a hellava spread difference on a 400 - 600hp car model). BTW, professional racing series sanctioning authorities also do their power "compliance" testing on engine dyno's. RW measurements are irrelevant to those folks.
But, knowing that many high performance car mod junkies "live and die" by rw dyno results, I asked Dinan to rw dyno my car when I picked her up there in 12/06. They graciously obliged and here is the report I wrote and posted: http://www.m5board.com/vbulletin/e39...-write-up.html . Bottom line is 530rwhp, in 1:1 5th gear, @ 7k RPM.
'Sorry for the long winded answer to your question. After many years of being "educated" about realities of measuring engine power output, by some of the very best engine builders on the planet, 'tend to get on my "soapbox" concerning unrelenting obsession with "bench racing" over rw dyno results. While not perfect, IMO, best way to compare/discover relative merits of any particular mods, on any particular car model, is side by side run's with "like" cars. Or, as some folks do, using GPS based dataloggers, on a before/after mod basis, to compare time/distance/speed differences.
PSS9 w/H & R sways
Dinan SSK
09-30-2008, 02:13 PM
40 grand for 100 hp!! WOW
09-30-2008, 03:14 PM
But, knowing that many high performance car mod junkies "live and die" by rw dyno results, I asked Dinan to rw dyno my car when I picked her up there in 12/06. They graciously obliged and here is the report I wrote and posted: http://www.m5board.com/vbulletin/e39...-write-up.html . Bottom line is 530rwhp, in 1:1 5th gear, @ 7k RPM's.
I understand your perspective regarding the dyno. The problem is, other than taking it to the strip. it is the best way to at least get some relevant info as to the changes the upgrades made. There are a ton of variables of course, and they vary from dyno to dyno.
Looks like your car is making some healthy power.
DCT M3 - 12.1@115
09-30-2008, 06:16 PM
I'd love to see the Dinan stroker go against an RD Sport stroker.
- 2007 Dodge Caliber SXT, in black
- 2009 Yamaha Raptor 700R SE
...eventually more stuff to come...
09-30-2008, 07:29 PM
Walks the standard M5, that thing must pull hard, but 40g's is indeed much for 100 h.p.
Nice regardless.
06 BMW M5 (Black)
07 MB E63 AMG (Black)
09-30-2008, 10:13 PM
Quote:
No sir it is not $40K. When it is all said and done it is $50K. You need to get other goodies to attain the stated 628 bhp.
There is and additional core charge of $20 which must be paid before they get your motor.
Remember it is not $50K for the Dinan stroker but you must also forfeit your motor. I have always stated that if you could keep your motor it would be a fair deal.
There is no doubt this is a great motor and well researched. It is obviously faster. For me spending this much money I want stupid crazy horsepower.
I would want to see dyno results to pin down exact rwhp which has been a subject of much debate. I will say that I hope a shot of nitrous is NOT used (unknown to most of us) during the dyno.
Seeing the stroker M5/M6 run the 1/4 mile and trap speeds is very important.
Running valid daily competitors is improtant. Running a well modded M5/M6 will be very informative.
Run a C6 Z06 vette in a rolling start, 50 to 160 mph.
I would love to see an E39 M5 with a Dinan S3 package run the stroker.
Dan run the M6 stroker out by you. I would pay to see that.
Personally I would love for someone here in So. Florida to purchase a Dinan stroker. I want one near me to pursue and do rolling starts and run head to head 1/4 mile runs. I would run on motor and with nitrous to see the difference.
My M5 on motor with the bolt on mods I believe can be close but who knows. I give the stroker credit.
There is a question. As the thread reads it is stated that there was a problem initially with the air intakes and/or MAF units. As these issues were resolved the car apparently became monsteribly more powerful.
But come on, intakes in these cars at best mean 20 bhp gains.
Anyway that is all okay. Just let the stroker run.
Honestly I truly want to line up with a Dinan stroker. Let the stroker put forward what it has and I will do my best.
All in the spirit of competition.
Ranger
09-30-2008, 11:29 PM
That is insane!!! 50k plus your motor...
10-01-2008, 01:42 AM
Very impressive all motor power, but as stated above, WAY too expensive. I'll just do the watching of the vids
10-01-2008, 06:49 PM
with the hit my portfolio took this year i shouldve just bought a stroker and enjoyed the money
2008 M5
10-01-2008, 07:31 PM
Moderator
Here's the Dinan stroker against a HPF M3, stock 997TT (with a driver that can't drive) and a Ford GT with unknown mods. The HPF M3 is a 6.85 second 60-130 car, which is about as fast as a Protomotive PE700, EVOMS GT700, or SG700 TT (all in the 580-600 rwhp range).
All in all the Dinan stroker is fast for a heavy car, but not what I could a very fast car overall. Looks nice, though.
Scott
'03 White 996 GT2 - 60-130: 5.49 w/ bolt-ons
'01 Black 996 TT - 889 rwhp (SOLD)
1/4 mile: 10.45/148 - 60-130: 4.67
'06 Black C6 Z06 - 722 rwhp (SOLD)
60-130: 5.74
'98 Quicksilver Supra - 720 rwhp (SOLD)
'03 Silver-Gray E46 M3 - 416 rwhp (SOLD)
10-01-2008, 09:16 PM
That Interlagos Blue M5 looks great with the HRE P40's but $50k for the stroker? That's ridiculous! It got owned by the HPF M3 but the most impressive car in that video is the Ford GT! It reeled in the M5 towards the end like it was standing still!
2004 TdF Challenge Stradale[/font]
--2003 996TT GT700
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-01-2008, 11:58 PM
The M5 had MAF problems in that movie. a non stroked tuned M5/M6 can take a stock 997TT
2006 BMW M6 alpine white (tuned by Kelleners) (euro)
2007 Audi A4 6MTQ black/black S-line (US)
2003 Audi S3 dolphin grey (euro)
1999 Mercedes-Benz E55 AMG (euro)
10-02-2008, 01:04 PM
The price tag is insane but WOW
Tags
2008, 628, bmw, dinan, e39, e60, hre, jrz, m5, m6, p40, road, s3, stroked, stroker, track, wheels  |
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
User CP
Visit our Sponsors
6SpeedOnline.com
Threads:
Members:
