RSW DINAN Power Upgrade Deals M3/M5/M235
Old 07-23-2015, 01:02 PM
Sales@RSW's Avatar
Sales@RSW is a splendid one to beholdSales@RSW is a splendid one to beholdSales@RSW is a splendid one to beholdSales@RSW is a splendid one to beholdSales@RSW is a splendid one to beholdSales@RSW is a splendid one to beholdSales@RSW is a splendid one to behold
Thumbs up RSW DINAN Power Upgrade Deals M3/M5/M235
Guys not sure if you are aware but we have just become a Dinan Authorized Independent dealer & Installation center. We want to let you know about the product offerings from Dinan. For those of you who are not aware Dinan is the ONLY aftermarket performance company that still allows you to retain your OEM BMW Warranty. All those other products are great but when something breaks on your dollar car, you can be stuck footing a very expensive bill.
The beauty of Dinan is that everything fits and works exactly like it should because of the level of R&D that goes into each of their products. We will be sharing some posts later comparing some of the Dinan hardware to its competitors to highlight some of the differences.
Dinan is not in the market to produce or sell anything that offers quality below that of the OEM. There are lots of manufacturers in this space that sell products that work, but frankly, aren't built to the standards of the pieces they are replacing. We strongly believe that if you're not replacing the parts on your car with products that are built to the same, or a higher level of build quality, that you are doing your vehicle an injustice.
As of right now the hot seller for the F80 chassis have been the Dinantronics tuners. We have found that compared to some of the other tunes available on the market the hardware is better designed, better made, and the cars tend to drive a little smoother with more predictable application of torque.
Dinantronics Info:
Please do not hesitate to call 908 223 7477 for pricing and availability!!! Right now Dinan is offering 10 percent of power packages!
F80 M3/M4 Parts
Below are some pictures of the harness just to give you an idea of the quality of the product you are getting. This is not something that was made with parts sourced from radio shack, this is a professionally assembled and designed motorsports level of quality harness.
And then there is the Control Unit itself:
D440-1644-ST1- $2499 MSRP CALL FOR DEALS OR PACKAGE PRICING
Product Specifications
DINAN STAGE 2
D440-1644-ST2:$2749 MSRP CALL FOR DEALS OR PACKAGE PRICING
This is the price for the software that requires an intake and recommends adding an exhaust.
DINAN CARBON INTAKE
D760-0045 $1999 MSRP CALL FOR DEALS OR PACKAGE PRICING
Carbon Fiber High Flow Air Intake for the F80 M3 and F82/83 M4:
+ More Power: Max gains of 14 HP @ 6000 RPM and 21 lb-ft of torque @ 3000 RPM when combined with the Stage 2 DINANTRONICS™ Performance Tuner and exhaust over stage 1 tuning.
+ Sportier Sound
+ ~20% Larger volume air boxes that completely seal
+ Optimized carbon fiber intake tube
+ 30% Larger cylindrical air filter
+ Larger MAF
+ Bolt-on installation
DINAN Free Flow Exhaust
D660-0050:$2499 MSRP
Benefits of the Free Flow Exhaust for the F8x M3/M4:
+ Maximum gain of +5 HP
+ Sportier sound
+ 100% 304 Stainless Steel Construction
+ Quad 3.5" laser engraved polished tips with Dinan logo
+ Computer controlled valve limits noise during low speed driving; valve opens fully during high-load conditions to allow free flow
+ Stock exhaust valve actuaters are reused
+ Operation of exhaust valve is unchanged so exhaust tone can be adjusted via the M-Drive settings.
+ Dinan exhaust is 3 lbs lighter than stock
+ Twin secondary exhaust valves with a whopping 76mm diameter, making them 45% less restrictive than the OE valves.
+ Includes mounting hardware
Exhaust Clip:
F10 M5 M6 Parts
D440-1636-ST1 Dinan Performance Tuner Stage 1 MSRP:$2999
Labor Hours/Installation Hours 2.00
Emission Status 50 State Emissions Legal. California Air Resources Board Executive Order Number D-176-42.
Max HP Gain 71 @ 3500 RPM
Max Torque Gain 106 @ 3500 RPM
Peak Horsepower 680 @ 6500 RPM
Peak Torque 644 @ 4000 RPM
BMW Factory Rated HP 560 (618 Measured)
BMW Factory Rated Torque 500
Included Notes DINANTRONICS™ Performance Tuner, Dinan® wiring harness, Dinan Stage 1 software
D440-1636-ST2 Dinan Performance Tuner Stage 2 MSRP:$3249
Max HP Gain 75 @ 4000 RPM
Max Torque Gain 109 @ 3500 RPM
Peak Horsepower 693 @ 6500 RPM
Peak Torque 651 @ 4000 RPM
Included Notes DINANTRONICS™ Performance Tuner, Dinan® wiring harness, Dinan Stage 2 software
Required Items Dinan® Carbon Fiber Cold Air Intake & Dinan Free Flow Stainless Exhaust for BMW F10 M5
D760-0035 Dinan Carbon Fiber Cold Air Intake MSRP:2999
Benefits of Dinans Cold Air Intake:
+ Maximum peak power of 693 HP and 651 lb-ft of Torque utilizing Dinan Stage 2 components (DINANTRONICS™ Performance Tuner, intake and exhaust). A difference of 13 HP and 7 lb-ft of torque from Dinan Stage 1 (D-TRONICS Performance Tuner Only).
+ Dinan proprietary Injection molded Dinan MAF housings are larger than stock
+ Stock air filters are replaced with 77% larger Dinan conical air filters.
+ Entire Dinan Intake system is sealed like a factory replacement to ensure only cold outside air and not hot air from the engine compartment is being utilized.
+ Stock System Stays Completely Functional
+ Carbon fiber air box lids and intake ducts
+ Raised Dinan logos are laminated into the carbon fiber intake
+ Rubber hoses, mounting brackets, & hardware included.
D660-0044 Dinan Free Flow Stainless Exhaust MSRP $3499
+ Improve performance by 8 horsepower
+ Throaty, deeper sound
+ Helmholtz chamber to remove drone
+ Incorporated Butterfly Valve technology
+ Simple installation using high quality BMW clamps and hangers
+ Quad 3.5" laser engraved black ceramic coated exhaust tips with Dinan logo
+ "Straight through" canister design
Exhaust Clip:
This can be ordered with black or stainless steel finished tips for no extra charge.
Please do not hesitate to call 908 223 7477 for pricing and availability!!! Will offer deals for packages of multiple pieces and even install labor discounts for local members.
BMW m235i Parts
D440-1641-ST1 Dinan Performance tuner Stage 1 MSRP $1999
Labor Hours/Installation Hours 1.50
Max HP Gain 38 @ 5000 RPM
Max Torque Gain 59 @ 3000 RPM
Peak Horsepower 364 @ 5500 RPM
Peak Torque 430 @ 3000 RPM
BMW Factory Rated HP 320 (326 Measured)
BMW Factory Rated Torque 330 (379 Measured)
D440-1641-ST2 Performance Tuner Stage 2 MSRP $2249
Max HP Gain 56 @ 5500 RPM
Max Torque Gain 83 @ 3000 RPM
Peak Horsepower 382 @ 5500 RPM
Peak Torque 455 @ 3000 RPM
Required Items Dinan® Carbon Fiber Cold Air Intake & Dinan Free Flow Stainless Exhaust for BMW F22 M235i
D760-0038 DINAN Carbon Fiber Cold Air Intake MSRP $599
Benefits of the Dinan Carbon Fiber High Flow Air Intake for the F22 M235i, F30/34 335i and F32/33/36 435i:
+ More Power: +10 HP & +15 lb-ft of torque without additional modifications
+ Even more power can be achieved when combined with the DINANTRONICS™ Performance Tuner and exhaust. Consult the applicable DINANTRONICS™ product page for details.
+ Sportier Sound
+ Larger volume air box that completely seals
+ Larger cylindrical air filter
+ Larger MAF
+ Quick and easy installation
D660-0048 Dinan Free Flow Stainless Exhaust MSRP $1799
Benefits of the Dinan® Free Flow Exhaust:
+ Helmholtz chamber to reduce drone
+ Enjoyably louder, sportier Sound
+ 100% 304 stainless steel construction
+ Twin 89mm laser engraved ceramic black exhaust tips
+ 6 HP @ 6600 RPM, 5 FT-LB
This exhaust can be ordered with Black or Stainless tips, and to fit the M Sport Rear valence or the stock rear bumper.
RIGHT NOW Dinan is offering a 10 percent discount on the entire P1 Power Package suite which is the Stage 2 Tune, the intake, and any exhaust for 4182, or 10 percent under the normal price. Please do not hesitate to call 908 223 7477 for pricing and availability!!!
Superaudiofreak
09-04-2015 03:22 PM
Quick Reply: RSW DINAN Power Upgrade Deals M3/M5/M235
