:: ECS Tuning :: Introducing The ECS E9X Rear Trailing Arm|Stronger Lighter
Old 10-20-2014, 02:38 PM
ECS Tuning - BMW's Avatar
While the BMW E9X is capable of sustained, high-performance driving, its suspension system is not without flaws. Specifically, the rear trailing arm fitted to these models has a tendency to fail without symptoms, potentially leaving you stranded without a critical suspension component.
ECS has solved this issue with a meticulously engineered Performance Rear Trailing Arm, made from aluminum & better designed to withstand the demands placed on it.
Not only is the unit more robust & dependable than the factory unit, it's also lighter, reducing weight.
•Constructed from solid 6061-T6 aluminum•
•Anodized for corrosion resistance•
•Increased strength versus the factory steel arm - this arm fears no pot holes•
•25% lighter (384 grams versus 517 grams each)•
Click HERE for your E9X ECS Performance Rear Trailing Arm Upgrade
Old 10-21-2014, 09:44 AM
Old 10-21-2014, 01:21 PM
Old 10-21-2014, 01:53 PM
Old 10-22-2014, 08:47 AM
Old 10-23-2014, 09:25 AM
Old 11-21-2014, 08:52 AM
Old 12-12-2014, 01:23 PM
Old 12-30-2014, 02:09 PM
Old 01-26-2015, 02:24 PM
Old 03-25-2015, 10:39 AM
Old 03-31-2015, 10:00 AM
Old 04-16-2015, 10:36 AM
Old 04-16-2015, 02:23 PM
Old 07-28-2015, 11:44 AM
Quick Reply: :: ECS Tuning :: Introducing The ECS E9X Rear Trailing Arm|Stronger Lighter
