Function First Shift Knobs For Your Boxter/Cayman!
Function First Shift ***** For Your Boxter/Cayman!
Boxster/Cayman 6Speeders! Dress up your shifting with shift ***** from Function First!
Does your Porsche exhibit rubbery and vague shifter feel? The factory shift **** is often overlooked as a source of this sloppiness, but it shouldn't be - comprised of mainly rubber and plastic, the OEM **** separates and numbs the driver from the mechanicals.
FUNCTION-FIRST Performance strives to reconnect drivers to their vehicles. Their Slotted Shift **** is machined from solid billet 6061-T6 aluminum to ensure that all shifting effort is transferred to the shifter, not lost to a flexing shift ****. The 2-inch diameter fits firmly in the palm, and is spaced high up to keep the shifting hand clear of the shift boot. The **** is designed specifically to fit Porsche's rectangular shifter shaft, and attaches securely via high-hold cone point set screws. Mounting height is customizable, ranging between 0.25-inches lower and 1-inch higher than stock.
The distinct slotted design reduces weight and delivers a no-slip grip, all while effectively shedding away the heat that commonly plagues standard billet shift *****.
The Function First Classic Shift **** is machined from solid billet aluminum and Delrin to ensure that all shifting effort is transferred to the shifter. The 2-inch diameter **** fits firmly in the palm, with the circumferential cutout providing dexterity and enhancing grip. The base shaft is designed specifically to fit Porsche's rectangular shifter, attaching securely via high-hold set screws, and allows for seamless integration of the OEM shift boot.
Function First Slotted Shift ****
Fitment
- Boxster (1997-04)
- Boxster S (2000-04)
- Boxster S Special Edition (2004)
Fitment
- Boxster (1997-04)
Fitment
- Boxster Limited Edition, Boxster RS 60 Spyder and Boxster S Limited Edition (2008)
- Boxster S Black Edition (2012)
- Boxster Spyder (2011-12)
- Boxster and Boxster S (2005-12)
Fitment
Fitment
- Cayman (2007-12)
- Cayman R (2012)
- Cayman S (2006-12)
Fitment
- Cayman (2007-12)
- Cayman R (2012)
smartbot
07-18-2016 01:15 AM
PelicanParts.com
996 Vendor Classifieds
10-07-2015 02:08 PM
PelicanParts.com
10-07-2015 02:07 PM
PelicanParts.com
993 Turbo Vendor Classifieds
10-07-2015 02:04 PM
PelicanParts.com
993 Vendor Classifieds
10-07-2015 02:04 PM
