Boxster / CaymanPorsche Boxster, Boxster S, and Cayman discussion board.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
I'd like to have a performance alignment done on my 2007 Cayman S. Does anyone have recommended specs? I'll be using it for AX, track, and street (but not daily driver).
Thanks!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on 6SpeedOnline!
I had a hard time finding the info and help on the 987 Boxster alignment specs online. I found a bit on Cayman Club but nothing too much. I've just adjusted my alignment a few day ago and I hope this will help others in the future.
2008 Boxster S with H&R spring on non-PASM
Front: Camber -0.67 to 0.33 Final -1.3
Toe 0.00 to 0.09 Final 0.00
Rear: Camber -1.60 to -1.10 Final -2.4
Toe 0.00 to 0.17 Final 0.15
I was able to get more negative front camber (than the factory setup) by move the top bolts inward. The performance setting feels and perform great. This is just what I'm using so please decide if this is right for yourself.
2008 LE Boxster S
2007 330i (Sold)
2006 MZ4 coupe (RIP)
2004 M46 M3 (Sold)
2002 911 S (Sold)
1997 Boxster (Sold)
These are just the general rules I go by for my 986S:
Zero toe in the front, maybe a little toe out if you will be racing it more than doing freeway driving. I go with zero toe on my car since I do drive it on the freeway and toe out feels really bad to me (twitchy) on the freeway.
A little toe in at the rear. I can't remember what I set mine to, but again, just a bit of toe in, NO toe out for sure (prone to snap oversteer).
I'm running about -2.3 degrees of camber in the front with Schnell camber plates and about -3.0 degrees in the rear. Those are both pretty extreme, but my car is also very low and I have fit issues in the rear that require the extreme camber. You might want to go to about -1.5 in the front and -2.0 in the rear for a street car or more like what I run for a track car. I think that -1.5 is the most you can get in the front stock though.
I agree with all of you. I just came from installing H&R springs (W stock struts) and final setup is:
FRONT: -1,5 camber and 0 TOE
REAR: -2.0 camber and +1,8 TOE
Im going to the racetrack this afternoon to see what happends.. but I made a quick test on a ramp exit and car was near perfect for a stock suspension
