6speedonline.com Forums
Go Back   6speedonline.com Forums > Porsche (Present) > Boxster / Cayman
Reply
Thread Tools Rate Thread Display Modes
Old 10-27-2008, 12:12 PM
Flyby's Avatar
Flyby is on a distinguished road
Squealing Brakes
Recently my '03 S was due for a new set of front/rear rotors, brake pads, and sensors. I had done the job myself and have had no issues in the past when replacing everything on my '99. Within the first few days I heard my brakes squeal and I assumed they were in the process of being broken in. A few days had gone by and the noise was still present, so I took the vehicle to my certified Porsche specialist, and he proceeded onto conducting a few 100-0 mph/40-0 mph stops and the noise had ceased for the time being. This occured this past Thursday and the noise is still present. If any of you have had similar brake discrepancies in the past or have any idea as to my current problem I am more than willing to listen. All input is greatly appreciated.
Sponsored Links
This ad is not displayed to registered members.
Register your free account today and become a member on 6SpeedOnline!
Old 10-28-2008, 03:10 AM
19000rpm's Avatar
19000rpm is a glorious beacon of light19000rpm is a glorious beacon of light19000rpm is a glorious beacon of light19000rpm is a glorious beacon of light19000rpm is a glorious beacon of light
Send a message via AIM to 19000rpm
Pop out the pads and use a file or grinder to bevel down the sharp edges on the heal and toe of the pad (the gray area in the pics below). You don’t even need to unhook the wear sensors. the sharp edges of the pads are what are causing the vibrations/noise. I guarantee this will fix it. I don’t know why Porsche insists on putting the sharp edge of the pad all the way out to edges, maybe they don’t want to sacrifice the extra pad area. make sure not to touch the pad surface while working and to give them a quick shot of brake clean just before reinstallation.
Old 10-28-2008, 05:30 AM
boxtaboy's Avatar
boxtaboy has a spectacular aura aboutboxtaboy has a spectacular aura about
I had the same problem when I installed Pagid brake pads on my 01. The fronts never squealed, but my rears squealed so much it drove me crazy, so I installed these anti-squeal brake pad liners, and it did the trick. You have to pull the pad out, and stick them to the BACK of the pad's backing plate. No more squealing brakes for me.
http://www.automotion.com/productpag...-Squeal+Liners
01 986 Arctic Silver, Dansk sports exhaust, 18in SSR GT3s
08 Brilliant Red Audi A4 2.0T Quattro
Old 10-28-2008, 08:41 AM
Tony@epl's Avatar
Site Sponsor
Tony@epl is on a distinguished road
Quote:
I have done this on numerous cars to take care of squealing issues. It works!
EuropeanPerformanceLabs, LLC
Custom Motronic ECU Tuning
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
203.345.6499
K24/18G SPECIAL:
2008 Cayman S : 1985 Audi URQ : 07 VW GTI
Previously posted as Nerdhotrod
Old 10-29-2008, 01:21 AM
Flyby's Avatar
Thank you all for your replies. I had no luck finding the anti-squeal pads locally. Come Thursday I am taking the pads and beveling them down with a file. Hopefully, the squeal will be eliminated and I will update you once I am done.
Old 11-02-2008, 04:26 PM
josh@iautohaus is on a distinguished road
Yup to make sure your covered i would remove the pads, chamfer the edges, apply BG stop squeak to the pads and break them in properly and you should be set.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
