Sponsored by Speed Merchants
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
Reply
Thread Tools Rate Thread Display Modes
Old 08-23-2009, 06:24 PM #1
Johnny Danger's Avatar
Johnny Danger can only hope to improve
Under Pulley
Does anyone have any experience with using a light weight under pulley on a 986 Boxster S ?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on 6SpeedOnline!
Old 08-25-2009, 09:29 AM #2
Cajundaddy's Avatar
Cajundaddy will become famous soon enough
Mantis Racing first developed the underdrive pulley for their 987 Cayman S. The idea is simply to slow down the accessories (power steering pump, alternator, AC compressor) on a car that spends a lot of time running high revs. 986/987 PS pumps are known to overheat and leak under heavy track use.
A side benefit is that the underdrive pulley reduces parasitic drag from these components and you can measure an increase in hp and torque at all rpms between 5-10 rwhp depending on the model. One size fits all 986/987 and there is no known downside to adding this as long as it is within your class rules for racing. Installation takes about 30 min with the special tool included in the kit. It's not a cool shiny CF bling item you can show off at cars & coffee, it just works. Way better than a reflash that gives a little boost in ponies only above 6500 rpm IMHO.
http://www.mantissport.ca/tabid/55/P...3/Default.aspx
98 Boxster 2.5L 5spd
PCA-GPX #129
Old 08-25-2009, 04:50 PM #3
Porschepet's Avatar
Porschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant futurePorschepet has a brilliant future
Cajundaddy
WOW !! great explanation and Post
Mantis and BBI are the 2 I see everyone using .have yet to hear about an unhappy customer from either vendor.
BBI just came out with a new lightweight version last friday and already has track tested its worthyness.
You cannot go wrong with either choice IMO
Cajundaddy makes a strong case for the mantis though . I did not know Mantis was the first .
Old 08-26-2009, 09:01 AM #4
CosmosMpower is on a distinguished road
Send a message via AIM to CosmosMpower
Does the crank pulley in these cars have any sort of harmonic balancer built in? On the M3 it did have one and the aftermarket units all deleted it and some motors let go.
2006 Lotus Elise
Canyon Red, Lotus sport suspension, Touring, Starshield, Stage 2 exhaust
Old 08-27-2009, 08:54 AM #5
tightbox is on a distinguished road
Do they make one for the 3.8?
Old 08-27-2009, 11:44 AM #6
Cajundaddy's Avatar
Quote:
A very valid question. I had to check with my expert to answer:
" On the M96 motor (986/996) it is a simple drive pulley with no harmonic balancer. On these cars the harmonic balance/dampening is achieved with the dual mass flywheel. The later M97 motor does incorporate a balancer with the drive pulley so an underdrive pulley install is a little more complicated."
If you drive a 986/996 the underdrive pulley is a simple change with no balance issues as long as the new one is true and balanced to begin with. I hope this answers your question.
PCA-GPX #129
Old 08-27-2009, 11:54 AM #7
boxtaboy's Avatar
2001 Porsche Boxster
boxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to beholdboxtaboy is a splendid one to behold
So would this underdrive pulley offer any benefits for cars that see no track use? How would it affect the efficiency of the a/c, water pump, and alternator during normal use?
01 986 Arctic Silver, Dansk sports exhaust, 18in SSR GT3s
03 OEM glass windowed soft top and frame retrofitted on my 01
Old 08-27-2009, 03:09 PM #8
justaddcoffee's Avatar
justaddcoffee is on a distinguished road
for normal street driving (rpms under 4k, let say) there's a slight effeciency benefit from the reduced drag. all of your accessories are simply running slower and using less energy. the downside is at idle and near-idle where your power steering pump is running below factory speed making the steering wheel a little harder to turn. also, never run underdrive pulleys if you have a lot of aftermarket electronic gear (subs, strobes, superasskickingoverthetop bling) because your alternator won't be running at minimum speed either.
- '99 twin screw m3 (sold)
- '05 boxster s
- '06 mini cooper s
Old 09-03-2009, 09:55 AM #9
Krokodil is on a distinguished road
This is somewhat incorrect. The M97.21 engine in the Cayman does not incorporate a harmonic balancer in the pulley. It is just stamped aluminum and can be replaced wih either the Mantis or BBi pulley.
I will not make this statement for all M97 derivatives as I am not positive.
Cheers,
Old 09-04-2009, 09:43 AM #10
Quote:
I purchased BBI's newest under drive pulley yesterday. They reverted back to making their pulley the same size as the oem. However, its 2/3rds lighter than the stock unit and the original belt is maintained. We'll see how it goes.
Old 09-04-2009, 11:07 AM #11
RSSbryan's Avatar
Premium Sponsor
RSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond reputeRSSbryan has a reputation beyond repute
RSS offers a lightweight underdrive pully made from 6061-T6 aluminum that has been very successful.
We have been making them for years.
The RSS kit comes with a wrench as well.
Feel free to contact us with questions.
Thanks.
Quote:
We are also launching a new harmonic balanced underdrive pully for 3.8 next week. Here is a sneak peak at the prototype:
Bryan – RSS | ROADSPORTSUPPLY & STUTTGART PERFORMANCE
SHOWROOM & TUNING CENTER: 714.545.1046 | 1275 S. LOGAN AVE., COSTA MESA, CA 92626
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
THE EXCLUSIVE U.S. DISTRIBUTOR FOR CARGRAPHIC
AUTHORIZED DEALER:
Old 09-04-2009, 08:09 PM #12
esq996tt is on a distinguished road
So what was BBI's rationale to go back to the stock size?
2007 BMW M6
2003 996tt daily driver - bone stock... 4 now
2000 Boxster S Track car
Old 09-05-2009, 02:26 AM #13
Quote:
I suspect their goal was to extoll the benefits of reducing the rotational mass of the pulley as compared to the stock unit, at the same time negating the need to change out and retention the drive belt. Makes sense to me.
Old 09-06-2009, 01:12 AM #14
Cartel's Avatar
Cartel is on a distinguished road
Send a message via AIM to Cartel
Thanks.
I could not agree more to the post above! Bryan was a tremendous help throughout the questioning process, shipping, and made sure a tech called me after the item was recieved to explain the installation process. Very well mannered and most importantly I noticed a difference in the way my car pulled. I look forward to ordering the EVOMSit software this up and coming week via RSS and than I will presume testing out these two new mods on the dyno. Once again, thanks bud.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l IPD Intake Plenum l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Old 09-06-2009, 11:05 AM #15
Porschepet's Avatar
RSSbryan
Can You PM me the price of your UP ,I am interested
I am assuming it will work on a 2007 2.7 Liter correct? Thanks so much
Reply
Tags
balancer, bbi, boxster, cayman, harmonic, kit, lightweight, mantis, pulley, racing, road, sport, supply, underdrive, underpully
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
User CP
Visit our Sponsors
6SpeedOnline.com
Advertising - Jobs - Privacy Policy - Terms of Service
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright Internet Brands
