Boxster / CaymanPorsche Boxster, Boxster S, and Cayman discussion board.
Welcome to 6SpeedOnline.com!
Welcome to 6SpeedOnline.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join 6SpeedOnline.com today!
The aftermarket H7 HID bulb has a wire run from the tip of the bulb to the bottom. When on, it projects the shadow of the wire to the ground, one on each side.
right. i have the same thing too. how do you remove the shadow??
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
I changed all the light including the fog, license plate city light and all the interior.
Side marker is the only error I got. I don't know why.... Could you send me the link of resistors?
Install/turn the bulb 180 degree from its orginal position. You have to trim/cut a little plastic on the base of the bulb in order to fit it in the socket. This will remove the shadow.
BINGO! thats all you needed to do. i am also playing with washers to get a better cut off with more colours. i find the cut off to be very dull right now.
maybe i should get some raptors. stupid ddm ballasts always throw me an error. i am guessing the raptors are one unit while the old ddm ones are ballast and ignitors separate?
The DDM Raptors have ballast and ignitors separate.
that is very weird. do you have the bulb out warning eliminators? i have them installed and all they do is keep my voltage constant. maybe i should purchase a set of raptor ballasts and give them a try. thanks for your help
