Psm failure on a 06 S after battery was installed backwards
Ever since a battery was installed backwards in this 2006 cayman S the PSM failure has stayed illuminate. No fuses were blown. I tried replacing the steering angle sensor with no change. Is there a piwis process that needs to be carried out after installing a new steering angle sensor? I have a piwis II. I would like to know all the components of the PSM system so I can track down which one was fried from this mishap. Thanks to all that can shed some light on this.
There is a process to do this but I do not know under what menu option it would be found.
With the older PST2 system it is "Calibrate steering angle sensor" and this is in the PSM menu and the PSM menu is accessible from the ABS menu.
