How About 50HP to Your 955 Cayenne Turbo?
Old 04-03-2014, 10:37 AM
vividracing's Avatar
When it comes to Turbo Porsche's, there is nothing else that can give you as much power and performance as the ECU flash. The Cayenne Turbo is no different than the 911. It has so much uncracked potential that the ECU flash lets out making the first generation Cayenne Turbo a thrill to drive. The 4.5L V8 engine is much more equipped once flashed. With stock 415hp at the crank, adjusting the trucks boost, fuel, and timing gives the Cayenne Turbo another 45 horsepower to the crank. With a gain of almost 90ft/lbs of torque, towing your other toys is like they are not even there. Furthering the performance of the Turbo truck is easily done with cat bypass pipes or a exhaust system. Because of the increased boost and horsepower, it is recommended to change your spark plugs to a 1 step colder plug if you have more that 10000 miles on yours. Expect to see boost increases to about 15psi.
Crank Horsepower Ratings:
Stock Power – 450HP and 457ft/lbs
Tuned Power – 495HP and 543ft/lbs
CONTACT FOR PRICING OR ORDER ONLINE HERE
With the VR Tuned ECU Flash, basic bolt-on performance parts will not require a retune of your ECU. Adding parts such as an exhaust, headers, air intake, throttlebody and plenum, will all adjust with the tune. Raising the secondary O2 limits for cat delete or high flow cats as well as raising the rev limiter is available upon request. If you add higher octane fuel, the ECU will adjust accordingly. Anytime you add higher octane, the fuel will burn slower providing your vehicle with improved performance. We never recommend using leaded gas such as C16 as this will destroy your O2 sensors and catalytic converters. Further custom tuning is available with provided dyno sheets or datalogging.
What are the benefits of VR Tuned?
  • #1 priority is our customer service to you!
  • Our tuning is used worldwide. We can provide you a tuned file no matter the octane you get or the environment you live in. We do both EU and USA vehicles running 91oct (95ron) or 93oct (98ron).
  • All ECU flashing is done via the OBDII port. We provide you the cable and all you need is a Windows base laptop or a Mac booted up as a windows machine.
  • There is no need for an internet connection, minimum processor requirements, or worrying about bricking your DME.
  • You can flash your ECU at your convenience without incurring any downtime where others require the removal of your ECU.
  • The VR Tuned flash client exports out your original file so you may flash your car back to stock at anytime.
  • The flash client saves your ECU information in a recovery mode if you incur any issues during the writing process so you can easily restore your file.
  • Basic scan tool functions that can view trouble codes and clear them are part of the software.
  • The flasher can read the entire file or just the programmable section.
Each VR Tuned order receives a special carrying case to hold your OBDII connector and cable. We include a wrench style USB stick to save your files on and also give you a nice VR stick on badge for your car or toolbox.
If you have any questions about the Porsche Cayenne 955 Turbo V8 ECU Flash, please contact our friendly support team!
View the HOW TO flash your vehicle instructions on the VRTuned.com site here. You can also view the video process below.
ID:	354952   Click image for larger version
ID:	354953   Click image for larger version
ID:	354954   Click image for larger version
ID:	354955   Click image for larger version
ID:	354958   Click image for larger version
ID:	354959   Click image for larger version
Old 04-11-2014, 10:31 AM
Anyone want to get flashed! Free Dyno if you are in AZ.
Old 09-19-2014, 12:07 PM
Making Friday deals on tuning! Call me for special offers. 4809663040 x222
Dan
Old 09-25-2014, 10:12 AM
Bump! PM for pricing
Old 09-30-2014, 08:24 PM
Waitin4Dv's Avatar
Waitin4Dv is on a distinguished road
Hey
Let me know what kinda deal I can get. Pm ya
Old 09-30-2014, 08:29 PM
Waitin4Dv's Avatar
Is possible to lower my caynne through this process or is it completly different the the dura metric tool? Still trying to get my cayenne lowered but no shop out here has ever done it. Might break down and buy the darn tool
Old 09-13-2016, 02:49 PM
CALMOTION's Avatar
CALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really niceCALMOTION is just really nice
Shout out to ViVid Racing. Just did my ECU Tune. Great service from Austin and Dan. Product is good and once you get a taste of it you want more. Dan how about another bump...LOL :-)
socialpro
Cayenne 958
05-18-2016 09:58 AM
PelicanParts.com
08-20-2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
08-20-2015 02:59 PM
PelicanParts.com
08-20-2015 02:57 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
Quick Reply: How About 50HP to Your 955 Cayenne Turbo?
