:: ECS Tuning :: 955 S Rear Driveshaft Center Support Bearing
If you hear or feel a thumping under your center console while turning corners or accelerating, it's likely the center support bearing in your cardan shaft has failed. Inspect the rubber around the bearing for tears, and move the driveshaft to check for excessive play at the bearing. A damaged bearing should be replaced immediately to prevent further damage. This bearing must be pressed on. Professional installation is recommended.
Click Here for more information
AJUSA.com
997 Vendor Classifieds
10-08-2015 05:50 PM
ECS Tuning - VW
08-19-2015 02:15 PM
