Drive shaft coupling Issue on Cayenne
For the DIY'ers, theres a place locally that refurbishes a driveshaft in exchange for your faulty one, I think they get $450 for one.
http://www.coloradodriveshaft.com/porsche_cayenne.htm
Here is another place (VertexAuto.com) that has them for $389 with a 1 year warranty. See: Porsche Cayenne Drive Shaft / Cardan Shaft
What are the steps to install shaft?
I'd be interested in knowing how to install the shaft. Thanks.
I antecedently pulled this joint apart on my s when i was installing the struts. i hyper extended the joint and all the ***** fell out. I rebuilt it myself and took a hole day just to figure it out. the dealer just replaces the whole shaft. pretty easy to install the shaft, though. If you try to tackle it your self i could tell you the steps.
i dont know if im having the same issue, when the car is on a full stop and i press on the gas and then remove my leg and press on the brakes the car vibrates "weird"....
it happens sometimes not all the time...
driving me crazy
driving me crazy
no not the wheels, im not sure if its the motor or underneath the driver seat.. someone told me it might be the low gear but i doubt it .. it feels like the car is gonna turn off but then it goes back to normal..
its an 05 CS has about 90 k on it
i think its the coil plugs cause sometimes there is some missing, and it feels like the engine is shacking... is there a site i can get them online cause here in jordan its expensive at the dealer ship? and which ones are better to buy??
thanks man
thanks man
Had mine done last fall. It seemed to have rougher shifts and there was some vibration when stopped on inclines. Replaced the Cardan shaft (2005) under CPO.
However, once it was done, the SUV carved corners like never before. She seemed more amenable to stearing by fine throttle inputs and drove more like a sports car.
guys can u plz let me know what exactly happens if you have a bad drive shaft, my 05 CS sometimes vibrates when i stop on inclines "weird vibration" they told me its either my d shaft or the low gear ,.. need your help
