Frozen lock, door won't shut
Old 12-12-2009, 08:00 PM
canberk's Avatar
canberk will become famous soon enough
Hello guys,
Today, I had problem shutting the front passenger door after getting in the car, as the door didn't shut. It just bounced back. It's due to cold weather and it went away by itself after it got warmer outside, and came back after leaving the car sitting in cold for another while.
Any suggestions? Should I spray something to locks? If so, what to spray and where to spray?
Don't say wd40 as it leaves a residue as it is petroleum based.
Old 12-12-2009, 08:43 PM
SoCal955's Avatar
SoCal955 is on a distinguished road
I have no idea what your talking about!
All jokes aside, I think there some sort of "lube" that repels the moisture, I think?
Old 12-12-2009, 08:44 PM
bbywu's Avatar
Originally Posted by canberk
Hello guys,
I use a graphite spray before each winter, and use silicon on all the door gaskets.
Old 12-12-2009, 09:55 PM
canberk's Avatar
Ha Ha SoCal955
Can any of you provide me a specific brand and type of spray, and more important, where to spray?
Old 12-12-2009, 11:09 PM
bbywu's Avatar
Gunk Dry Graphite...good to -37F
The reason your door isn't shutting is because the locking latch isn't clasping down then the striker bar pushes inward. It is possible you got some water in the mechanism. Spray the graphite generously into the latch. It's going to make a mess. Make sure you have a towel. Open and shut the door a dozen times. Respray. Once the graphite spray dries, it will coat the latching mechanism. It should take care of the problem.
Old 12-12-2009, 11:10 PM
bbywu's Avatar
Yes...it's called WD-40. Water Displacement...but he doesn't want to use it (I probably wouldn't either.)
Old 12-13-2009, 04:00 PM
SoCal955's Avatar
Actually I wasn't thinking of WD-40, I was thinking of something similar to what you described, but being from So Cal, I would not have a need for it.
Old 12-13-2009, 06:42 PM
bbywu's Avatar
All of you and your warm sunny weather...I hate you
Old 12-13-2009, 07:54 PM
canberk's Avatar
this picture reflects the way my cayenne looked like the other day.
It was below zero, and it started snowing here the other night, after a LOT of snow, it switched to rain, while the temperature was sub-zero, and my car ended up becoming an ice cube...
Old 12-13-2009, 08:55 PM
bbywu's Avatar
Not sure graphite is going to help you with this much ice
Old 12-13-2009, 10:00 PM
SoCal955's Avatar
I rest my case, sunny San Diego all the way!!
Old 12-13-2009, 10:12 PM
canberk's Avatar
i'll be there next week (seriously)
NC 996TT
03-23-2023 06:19 AM
NIKAS
08-20-2019 07:53 PM
keeperofbeasts
11
04-03-2017 10:53 AM
lokmeup
09-09-2015 09:24 PM
sparks
09-08-2015 03:03 PM
Quick Reply: Frozen lock, door won't shut
