Parking Sensors
Parking Sensors
Hello;
New Cayenne S owner here (2004). My first Porsche ! I blame my buddy and his 86 911 getting into the game.
Anyway, when I turn the Parking Sensors on; I only get 2 reds left and right with no in-betweens (front). I assume there's a bad sensor (any other thoughts are appreciated).
If so, anybody know how to remove/replace these ? I'm pretty handy, so figure can work on myself.
Hello;
Here are some items to check on,
1) If they were ever repainted they can be removed, sanded down, polished and re-install.
2) Make sure they are connected correctly, sometimes you might just have a loose connection causing this error (it's more common if you've had service or body work requiring front bumper removal.
3) If all else fails you can plug in and find out should you have access to the proper PIWIS
Nobody has ever tried this ? I'm pretty sure they just push in / pull out...Like to know before I pry them out... No worries, for some reason, mine has an odd black lower-bumper protector (that I don't like anyway)...
Hello;
Thanks!
Yeah, sure did. Most of my connectors were loose or dirty where they connect to the sensor. They were loose because the little 'catch' that holds the clip on had broken off (plastic). So, I took each apart, cleaned the contacts, then reconnected. To keep from coming apart, used a thin zip tie around the unit/clip. Worked great and no more issues !
First, I did test each one to ensure its not just a single failure. Clean them off very well. In doing so, most didn't work. When functioning, they'll 'click' slightly and you can feel when touching the sensor.
Awesome! Thanks for getting back to me. I'm going to test them this weekend and then take off the bumper and clean them. I could tell that the side ones, that you can see, were very dirty and had lots of cinder (they use it on the ground here when it snows) caked on. Hoping to solve this one soon. Thanks, again and wish me luck.
You can wash them off anyhow you like to start (remove most of the grime), then...
I used a Q-tip and alcohol since it leaves no reside behind and dries (evaporates) quickly. Ensure you don't wax/polish them you have the car detailed either.
They're best unscathed...
Sorry to bug you, but you used alcohol on the contacts or just the outside where they are visible? I figured out the outside, just wanted to do it right for the connections and contacts. I like the idea of using electrical contact cleaner but since I don't have that handy...
believe he means on the actual connetctions, its a good way to get those squeaky clean without damage or residue. I couldn't hurt to use it on the outside as well, would most likely effictively remove any wax/sealant that could be causing a problem.
I would add that in my experience with other makes and models, a coat of wax or even a light coat of paint doesnt impede the sensors ability to function, most issues are a result of impact or electrical fault of some kind.
