Falken RT-7M wheels - 20"
Anyone have a set of Falken RT-7M wheels on their Cayenne? Any feed back? The offset is aggressive (same as rear wheels on GTS).
http://www.discounttiredirect.com/di...=10&vid=016138
I am looking at putting a set of 20s on my GTS in summer as I need good all season tire to visit construction sites a couple times a week.
They look good. But the 22s are only 9.5 wide, the 20s are 10 wide. Both are a 45 offset, so the outside edge of the 22s will be 6mm inward compared to the 20s (and 1mm inward from a stock 21 GTS wheel).
Yes, the 20" I think would be no problem especially if it's a gts model as mine is inward and by adding 6mm you would be ideally placed. Especially if you ordered through discount tire, their fitments are conservative and fairly accurate. I just went with the biggest diameter possible. 20" would offer a bit more side wall I would imagine for your intended use
WheelB
01-06-2018 11:08 AM
ModBargains
08-20-2015 12:28 PM
