cayenne turbo upgrade turbo chargers
This thread died. Let's resurrect!
1. Are the turbo manifolds different on the 955 and the 957? I imagine they are, but if not, just swapping to the TD04s would be an inexpensive upgrade.
2. If different, it should be fairly simple to have the RHF5s modified to flow better. A brand new turbo is only $850 from Suncoast. Does anyone have any ideas on that or someone who has already modified or "hybrid"ized?
Looking at TD04 Turbochargers online (universal...the exh inlet flange looks to be the same...so a TD04 should bolt on. BUT. all the oil and water lines would be another story, possibly different routing, etc. I dont know what the exhaust outlet flange is on the TD04, but on my 04 CTT the exhaust flange is a weird 5 star pattern and its huge (4+"??)! I cant find a place that sells just the flange. So I am going to have some made and some primary delete pipes made
My big question is: Has anybody ever removed and installed a turbo without removing the engine!? It's a tight fit in there. lol.
I like this thread, lol
Engine should not be "that hard" to get out. Just like doing a turbo swap on a B5 S4 Audi.
Thread bump since it's the ONLY thread I've found in regards to upgrading the turbos. Aside the fact of this being a Porsche, a turbo is just a turbo, so I'm surprised I don't see more threads in regards to making them larger and/or just upping the boost. The stock gauge reads .8 bar which is only like 11psi, which means each turbo is only putting out 5.5psi...that's nothing!! Why can't a good ol fashioned boost controller like a Greddy Profec be used, a fuel pressure regulator that rises the fuel rate at 1:1 with the boost and a larger fuel pump...just like every other vehicle out there. What are the stock injector sizes? What is the stock fuel pump(s) size?
I'm looking at an 05 CTT w/ a yet to be determined intake kit, muffler and maybe some other exhaust options (deleted 2nd cats, etc as I haven't been under the truck to look), but I'm still surprised how quiet the turbo and BOV is on these. The truck was quite laggy off the line, but once the boost came on, it definately had some power! I expected to hear howling and a huge WOOOSH...instead the turbos were as loud as if I'd cracked the window and I had to have the windows down just to hear the BOV.
So much mis-information and nonsense. This has all been covered at least 10 times in ten different threads. If the 6speed search function isnt working for you the be assured google is your friend. The stock turbos are NOT k16's they are rfh5 anf they are rated by ihi @ 210 hp each. There are several hybrid options that will get you to around the 700hp mark. Please do not post "opinions" and try to back up claims with some fact or supporting evidence. Why people join here or come on and post demands for information and help is beyond me. Theres no free lunch.
So you can say that if an engine flows 1000 CFM, each turbo is flowing 500 CFM. You cannot use this same relationship for pressure though.
This is NOT true at all. Centrifugal pumps (of which turbos are a subset) will double in flow when run in parallel. When run in series, pressure is doubled. 99% of turbo systems are run in parallel including the Cayenne.
M5James, Welcome! There is not a lot of good information on this thread and loads of misinformation as Mr. Haney pointed out.
I assure you that there other turbo upgrade threads available on the boards. Something to keep in mind is that to replace the turbos on this platform, it is spec'd to be over 30 hours to drop the engine and replace. As such, there are very few turbo swaps out there.
If this is out of your budget (like most people), then I suggest changing tracks and start looking for bolt-on upgrades.
All said, if you are still interested, please open a new thread.
3WDistributing
31
10-27-2017 01:26 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-18-2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-18-2015 03:41 PM
