Fill up tires using PASM on '11 Cayenne
Filling up tires using PASM on '11 Cayenne
I don't see where the nozzle is located nor does it say in the manual. Any thoughts?
Ah, must have moved it with newer models. Mine's an 04; sits under the rear seat. Then again, I have no spare (crappy Bose) just an air hose and a bottle o' goo.
+1 04 its under the left rear seat in a white bag. New ones couldn't tell ya, but i found mine using the owners manual.
Fyi,air suspension and Pasm are standard on the turbo
That was not his point. Even standard, it is the air suspension that has the hose and ability to fill tires. PASM is simply a valved shock suspension system that can work alone or in conjunction with air suspension
It does actually have air suspension but all there is under the front passenger seat is a storage box and there is no hose next to the spare tire. What surprises me is that in the manual it says you can either fill up the spare tire using air suspension (although not specifying where!) OR using the battery charged air pump, which usually takes forever.
horsepowerfarm
09-10-2015 06:09 PM
LiquidElephant
08-27-2015 06:17 PM
PelicanParts.com
08-20-2015 02:57 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
