Headlight gasket/seal replacement
I've been noticing the gasket that seals the area between the headlights and the fenders have been falling apart for a little while so I just replaced them this weekend. It was also causing the headlights to bounce and you could see that effect driving at night over bumps. Very simple, but there are several plastic tabs that hold them on. I broke one but it wasn't anything some silicone and then tape to hold it until it dries couldn't fix.
One unexpected thing I got out of it is the Evoms intakes aren't as loud as before, odd as that seems. There is definitely less "whoosh" sound when it's sucking in air and when the DVs release the boost back into the inlets. I had no idea that would have any effect on the intake noise, but there you have it - some nearly useless info for the cayenne.
If the headlights are bouncing, the first thing I would look at are the mounting cradles. They can come loose, to the point of the bolts falling completely out. There are 4 mounting points.You can either tighten them up, or take the bolts out, one at a time as to not lose the adjustment, and loctite them back in. I also recently replaced my seals, looks MUCH better.
Yes. I had tightened the brackets several months ago and while there were a couple loose, it was the seals that stopped it altogether.
Headlight seals
Anne123,
This should be fairly simple. In your toolkit, you should have a tool for removing the headlights. Very simple to do and the instructions are in your manual. The headlight comes out as a unit and this is also how the bulbs are replaced. With the headlight out, the seal replacement should be self evident.
What if you don't replace the seals and if so, what may be the consequences? I mean, seriously, its $50 per seal each side and I rather use that $100 toward dentpro to fix some of the dings i got instead..just wanted to get some understanding here..thanks!
Wow, way to bring a thread back from the dead On the same note though I kind of wondered exactly what purpose the gaskets served too. They don't seal the headlight itself. Guess they just keep water from getting inside the fender well? Again,one of those parts that makes you realize why Porsche is so profitable. I agree $50 each seems steep for some foam rubber.
I know this thread is old, but I want to share this info to help anyone looking in the future.
Mine were stiff and cracked, so I just changed them while replacing my cornering bulbs. The installation was simple.
I purchased them from pelicanparts.com. You can search by the part numbers below. They are pricey for rubber/plastic seals, but I want to keep my headlights working.
Left ($57): 955-631-115-00-M100
Right ($65): 955-631-116-00-M100
LiquidElephant
08-27-2015 06:17 PM
PelicanParts.com
08-21-2015 01:37 PM
PelicanParts.com
Audi Vendor Classifieds
08-21-2015 01:28 PM
PelicanParts.com
08-20-2015 04:01 PM
