COMPLETE CAYENNE LED Interior Light Change-Over Tutorial
FYI, it is possible to remove the little plastic light bulb housing, say you accidentally have the bulb drop out of it's socket in there. Just remove the 4 screws at the corners of the mirror. You'll have to flex the mirror housing plastic a little bit, but it can come out.
It also makes it a lot easier to reach everything if you undo the connector to the mirror glass.
Also, the mirror housing can flip toward the front of the car to make things more accessible.
Great tips, thanks!
Ahhh looks like the vendor made a change. Here is the style you want:
http://cgi.ebay.com/ebaymotors/20x-T...item33639be5af
If it looks like that, It will work.
http://cgi.ebay.com/ebaymotors/20x-T10-W5W-501-8-LED-No-Error-Canbus-LED-White-Lights-/220714493359?pt=Motors_Car_Truck_Parts_Accessories &hash=item33639be5af
Thank you for the new link and the write up. I will let you know how the install goes. Where in NJ are you located btw?
I'm about 5 minutes from the meadowlands and always happy to show the car to a fellow 6speeder.
YUP - no issues, no warnings - all good!
Any tips on removing the rear cargo-light housing? I have plastic pry-tools commonly used by interior installers... just not sure where on the housing to pry from.
